Add Variable Based Suitability Criteria (Business Analyst Tools)
Summary
Adds criteria based on the values calculated for the input layer using the Enrich Layer tool.
Usage
You must be signed in to ArcGIS Online or connected to a locally stored dataset.
The input analysis layer can be created using the Make Suitability Analysis Layer tool.
The selected variables are used to enrich the site layer.
Set the influence for each criteria using the Set Criteria Property tool.
Parameters
| Label | Explanation | Data type |
Input Suitability Analysis Layer |
The Suitability Analysis layer that will be used in the analysis. |
Feature Layer; Group Layer |
Variables |
The variables from which the suitability criteria will be determined. |
String |
Derived output
Output Suitability Analysis Layer |
The name of the Suitability Analysis layer that will be added to the map. |
Feature Layer |
Output Criteria Name |
The name of the criteria that will be added to the Suitability Analysis layer. |
String |
Environments
Current Workspace, Data Source
Licensing information
- Basic: Requires Business Analyst
- Standard: Requires Business Analyst
- Advanced: Requires Business Analyst
