Detect Graphic Conflict (Cartography Tools)
Summary
Creates polygons where two or more symbolized features graphically conflict.
Illustration
Detect Graphic Conflict tool illustration
A pink output polygon is created where the symbology of a blue input river feature conflicts with the symbology of a yellow road conflict feature.
Usage
  • This tool assesses conflicts among symbols, not geometry. The input layer and the conflict layer can be the same.
  • Input layers must be symbolized. Input layers can include feature class annotation, including symbol substitution. Shapefile and CAD layers are also acceptable inputs.
    The following inputs are not accepted by this tool:
    • CAD annotation
    • Coverage annotation
    • VPF annotation
    • Dimensions
    • Raster layers
    • Network datasets
    The following symbology types are not accepted by this tool:
    • Chart symbology
    • Dot density symbology
    • Proportional symbols symbology
    • Unclassed colors symbology
    • Heat map symbology
    • Dictionary symbology
    • Any symbology containing 3D symbols
  • The output feature class stores polygons, each representing an area of graphic conflict between a symbolized input feature and a symbolized conflict feature. The feature IDs associated with the two conflicting features are stored with the conflict polygon in the FID_<input_layer_name> and FID_<conflict_layer_name> fields. If the conflict layer is the same as the input layer, the second field will be named FID_<input_layer_name>_1. If no graphic conflicts are found, the output feature class will be empty.
  • Use the Conflict Distance parameter to detect areas where input and conflict symbology is closer than a certain distance. Temporary buffers one-half the size of the conflict distance value are created around symbols. Conflict polygons will be generated anywhere these buffers overlap. When the conflict distance is zero, conflicts are detected anywhere that symbology actually overlaps; this is the default. The conflict calculation is based on a reference scale. The reference scale of the data frame containing the input layers is used unless the Reference Scale environment setting has been set.
  • Use the Line Connection Allowance parameter to disregard symbol overlaps where line ends meet. This is useful if you use line symbol end caps to ensure that lines connect visually, but you don't want each instance detected as a conflict. The line connection allowance is in page units, related to the reference scale. It is equal to the radius of a circle, centered where lines join, within which graphic overlaps won't be detected; the default value is 1 point. Use a value that is at least one-half the line width of line symbols to disregard these connections. A value of zero means no allowance and a conflict will be detected at each line join. This parameter is only considered when the input layer and the conflict layer are identical.
  • This tool assesses graphic conflicts of symbolized features. The symbology extent and the reference scale are used in conjunction with one another. Run this tool only after you have finalized the appearance of the symbols, and ensure that the reference scale corresponds to the final intended output scale.
  • Processing large datasets may exceed memory limitations. In this case, consider processing input data by partition by identifying a relevant polygon feature class in the Cartographic Partitions environment. Portions of the data, defined by partition boundaries, will be processed sequentially. The output feature class of conflict polygons will be clipped at polygon edges.
Parameters
Label Explanation Data type
Input Layer
The input feature layer containing symbolized features. CAD, coverage, or VPF annotation, and dimensions, charts, dot-density or proportional symbols, raster layers, network datasets, and 3D symbols are not acceptable inputs.
Layer
Conflict Layer
The feature layer containing symbolized features that are potentially in conflict with symbolized features in the input layer.
Layer
Output Feature Class
The output feature class that will be created to store conflict polygons. It cannot be one of the feature classes associated with the input layers.
Feature Class
Conflict Distance
(Optional)
The area where input and conflict symbology is closer than a certain distance. Temporary buffers one-half the size of the conflict distance value are created around symbols in both the input and conflict layers. Conflict polygons will be generated where these buffers overlap. Conflict distance is measured in page units (points, inches, millimeters, or centimeters). If you enter a conflict distance in map units, it will be converted to page units using the reference scale. The default conflict distance is 0 in which no buffers will be created and only symbols that physically overlap one another will be detected as conflicts.
Linear Unit
(Optional)
The radius of a circle, centered where lines join, within which graphic overlaps will not be detected. This parameter is only used when the input layer and the conflict layer are identical. Zero allowance will detect a conflict at each line join (if end caps are overlapping). Line connection allowance is calculated in page units (points, inches, millimeters, or centimeters). If you enter an allowance in map units, it will be converted to page units using the reference scale. The value cannot be negative; the default value is 1 point.
Linear Unit
Environments
Cartographic Coordinate System, Reference Scale, Cartographic Partitions
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Yes
