Float to Raster (Conversion Tools)
Summary
Converts a file of binary floating-point values representing raster data to a raster dataset.
Legacy:
This is a deprecated tool. The Copy Raster tool can now be used to convert a float file representing raster data to a raster dataset.
Usage
The input file is an IEEE floating-point format, 32-bit signed binary file.
Two inputs are required: the binary floating-point file with a
.fltextension (<in_float_file>.flt) and an ASCII header file with a.hdrextension (<in_float_file>.hdr). You only specify the.fltfile; however, there needs to be an existing.hdrfile in the same directory with the same file name.The ASCII file consists of header information containing a set of keywords.
There are two variations of the structure of the ASCII file. One identifies the origin by the coordinates of the lower left corner of the lower left cell, the other as the center of the lower left cell.
The format of the file in general is:
NCOLS xxx NROWS xxx XLLCORNER xxx YLLCORNER xxx CELLSIZE xxx NODATA_VALUE xxx BYTEORDER <MSBFIRST | LSBFIRST>The definitions of the keywords are as follows:
NCOLSandNROWSare the number of columns and rows in the raster defined by the binary file.XLLCORNERandYLLCORNERare the coordinates of the lower left corner of the lower left cell.You can also use
XLLCENTERandYLLCENTERto specify the origin by the coordinates of the center of the lower left cell.CELLSIZEis the cell size of the raster.NODATA_VALUEis the value that is to represent NoData cells.BYTEORDERrepresents how multibyte binary numbers are stored on the system on which the binary file was generated. On Intel CPU-based systems, the byte order isLSBFIRST(also known as Little Endian). On most other architectures (most UNIX systems except Alpha, and older Macintoshes with Motorola CPUs), the byte order isMSBFIRST(also known as Big Endian).
The
NODATA_VALUEis the value in the input file that determines which cells should be assigned the value of NoData in the output raster. NoData is normally reserved for those cells whose true value is unknown.In a floating-point binary file, the values are written as binary 32-bit signed floating-point numbers. The first record of the file corresponds to the first row of the raster. Going from left to right, the first 32 bits are the first cell, the next 32 bits are the second cell, and so on, to the end of the record (row). This is repeated for the second record (the second row of the raster) and all the way until the last record (the bottom row of the raster).
This tool supports both the lower left corner and the center of the lower left cell for determining the origin.
Once the output raster has been created, use the Define Projection (management) tool to give it the appropriate coordinate system.
Certain Raster storage environments may apply to this tool.
Parameters
| Label | Explanation | Data type |
Input floating point raster file |
The input floating-point binary file. The file must have a |
File |
Output raster |
The output raster dataset to be created. If the output raster will not be saved to a geodatabase, specify |
Raster Dataset |
Environments
Auto Commit, Compression, Output CONFIG Keyword, Pyramid, Scratch Workspace, Tile Size
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
