Raster to ASCII (Conversion Tools)
Summary
Converts a raster dataset to an ASCII file representing raster data.
Usage
The input raster dataset can be any valid raster dataset.
The structure of the ASCII file consists of header information containing a set of keywords, followed by cell values in row-major order.
The format of the file in general is:
NCOLS xxx NROWS xxx XLLCORNER xxx YLLCORNER xxx CELLSIZE xxx NODATA_VALUE xxx row 1 row 2 . . row nThe definitions of the keywords are as follows:
NCOLSandNROWSare the number of columns and rows in the raster defined by the ASCII file.XLLCORNERandYLLCORNERare the coordinates of the lower left corner of the lower left cell.CELLSIZEis the cell size of the raster.NODATA_VALUEis the value that is to represent NoData cells.In the data stream of cell values, row 1 of the data is the top of the raster, row 2 is just under row 1, and so on.
An example of an ASCII raster file is:
NCOLS 480 NROWS 450 XLLCORNER 378922 YLLCORNER 4072345 CELLSIZE 30 NODATA_VALUE -32768 43 2 45 7 3 56 2 5 23 65 34 6 32 54 57 34 35 45 65 34 2 6 78 4 2 6 89 3 2 7 45 23 5 ...NODATA_VALUEin the example above is the value in the ASCII file that will represent cells that are NoData in the input raster. This value is normally reserved for those cells whose true value is unknown.The end of each row of data from the raster is terminated with a carriage return character in the file.
Both integer and floating-point rasters can be converted to an ASCII raster file.
This tool only writes the origin as the lower left corner of the lower left cell. The Copy Raster tool also supports the origin as the center of the lower left cell.
At ArcGIS Pro 3.2 and later, the default tool output is an ASCII file with an
.ascextension, not a.txtextension. For existing ASCII files with a.txtextension, renaming the file using the.ascextension is recommended.
Parameters
| Label | Explanation | Data type |
Input raster |
The input raster dataset. The raster can be integer or floating-point type. |
Raster Layer |
Output ASCII raster file |
The output ASCII raster file. |
File |
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Current Workspace, Extent, Geographic Transformations, Output CONFIG Keyword, Output Coordinate System, Scratch Workspace
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
