Raster to Point (Conversion Tools)
Summary
Converts a raster dataset to point features.
Usage
For each cell of the input raster dataset, a point will be created in the output feature class. The points will be positioned at the centers of cells that they represent. The NoData cells will not be transformed into points.
The input raster can have any cell size and may be any valid raster dataset.
The Field parameter allows you to choose which attribute field of the input raster dataset will become an attribute in the output feature class. If a field is not specified, the cell values of the input raster (the
VALUEfield) will become a column with the headingGrid_codein the attribute table of the output feature class.If Extent is specified in the environment setting and the lower-left corner of the output extent does not match any cell corner of the input raster, during processing, a shift of the cell alignment of the input raster will occur to match the specified extent. This shift will trigger a resampling of the input raster using the Nearest Neighbor method. Consequently, the output features will shift as well, and the resultant output features may not overlay the original input raster exactly. You can avoid this shift by using the input raster as the Snap Raster in the environment.
Parameters
| Label | Explanation | Data type |
Input raster |
The input raster dataset. The raster can be integer or floating-point type. |
Raster Layer |
Output point features |
The output feature class that will contain the converted points. |
Feature Class |
Field (Optional) |
The field to assign values from the cells in the input raster to the points in the output dataset. It can be an integer, floating point, or string field. |
Field |
Environments
Auto Commit, Current Workspace, Default Output Z Value, Extent, Geographic Transformations, M Resolution, M Tolerance, Output CONFIG Keyword, Output Coordinate System, Output has M values, Output has Z values, Output M Domain, Output XY Domain, Output Z Domain, Scratch Workspace, Snap Raster, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
