Update Features With Incident Records (Crime Analysis and Safety Tools)
Summary
Updates an existing table or converts a nonspatial table to point features based on x,y-coordinates or street addresses and updates an existing dataset with the new or updated record information from the table.
Usage
  • A point feature class, point feature layer, or table must exist where records from the input table will be appended or updated.
  • You can use tabular data exported from a computer-aided dispatch system or records management system in this tool.
  • This tool supports the following table formats as input:
    • Geodatabase
    • dBASE (.dbf)
    • Microsoft Excel worksheets (.xls and .xlsx)
    • Memory-based tables
    • Delimited files
      • Comma-delimited files (.csv, .txt, and .asc)
      • Tab-delimited files (.tsv and .tab)
      • Pipe-delimited files (.psv)
    For delimited files, the first row of the input file is used as the field names on the output table. Field names cannot contain spaces or special characters (such as $ or *), and an error will occur if the first row of the input file contains spaces or special characters.
  • Performing geocoding operations using the ArcGIS World Geocoding Service requires an ArcGIS Online organizational account and consumes credits. The organizational account must have enough credits to complete the entire geocoding request.
  • When the optional Invalid Records Table parameter value is created, the table contains records that were not processed as new or updated features. The complete input table record will be added to the Invalid Records Table parameter value as well as an INV_REASON field. The INV_REASON field will include a code identifying the reason the record could not be processed as new or updated features.
    The INV_REASON field is added to the Invalid Records Table value with the following error codes:
    • NULL_ADDR—All address fields in the input table record contain null values.
    • NULL_ID—The input ID fields of the input table record contain null values.
    • NULL_XY—The input table's x- and y-coordinate fields contain a null value.
    • BAD_DATE—The input date of the input table record is null or could not be converted to a valid date.
    • BAD_ADDR—The address candidate from the input table record is unmatched.
    • BAD_FM—The field mapping of the input table record was unsuccessful because a value could not be written to the output field. For example, text values cannot be added to numeric fields, and text values cannot be added to text fields when the values are longer than the field length. When this code occurs, the INV_FLD field is added to the Invalid Records Table value and lists the fields from the Input Table value that contain values that could not be written to the Target Features value.
    • DUP_ID—The input table record has a duplicate ID and has not been updated to the target features because it is older than the existing record or a newer record exists. This is determined by the last modified date. If the last modified date is not used, it is determined by the highest OBJECTID value.
    • APD_ERR—The input table record could not be appended to the target layer due to an unexpected error while processing.
    • UPD_ERR—The input table record could not be used to update the corresponding target record in a feature service due to an unexpected error during processing. When this code occurs, the INV_FLD field is added to the Invalid Records Table value and lists the feature service error code and the error description encountered while processing.
    Tip:
    A common reason the UPD_ERR or APD_ERR error code is identified is the existence of HTML content stored in the fields input table. This causes an error because the default configuration of feature services prevents the appending of HTML values into a field.
    When no Invalid Records Table parameter value is provided, an invalid_records_<timestamp>.fid file is created in your scratch workspace environment. This file will contain the OBJECTID value of each Input Table record that could not be added or updated in the Target Features parameter.
  • When both the Update Existing Target Features and Update Geometry for Existing Features parameters are checked, location fields in the Input Table parameter value are compared to the location fields in the Target Features parameter value to determine whether the geometry will be updated in the Target Feature parameter value. When Location Type is set to Addresses, the Address Fields values are compared. If a difference is detected between the Input Table record and the Target Features parameter values, the Target Features geometry is updated with the geocoded position based on the address fields in the Input Table record. The Input Table record will not be geocoded if no difference is detected.
  • When the layer specified in the Target Features parameter value is a feature service layer, use the Convert Dates To UTC Time Zone parameter to specify whether date values from the Input Table will be converted to coordinated universal time (UTC). Date values are assumed to be in the same time zone as the local system.
Parameters
Label Explanation Data type
Input Table
The nonspatial table or table containing the x- and y-coordinates or addresses that define the locations of the records.
Table View
Target Features
The point feature class, point feature layer, or table that will be updated.
Feature Layer; Table View
Location Type
(Optional)
Specifies whether features will be created using x,y-coordinates or addresses.
This parameter is only active when the Target Features parameter value is a feature class or layer.
  • Coordinates—Features will be created using the x,y-coordinates of the input record.
  • Addresses—Features will be created using the address of the input record using a locator.
String
X Field
(Optional)
The field in the input table that contains the x-coordinates (or longitude).
This parameter is only active when the Location Type parameter is set to Coordinates and the Target Features parameter value is a feature class or layer.
Field
Y Field
(Optional)
The field in the input table that contains the y-coordinates (or latitude).
Field
Coordinate System
(Optional)
The coordinate system of the x- and y-coordinates.
Coordinate System
Address Locator
(Optional)
The address locator that will be used to geocode the table of addresses.
When this parameter is set to use ArcGIS World Geocoding Service, this operation may consume credits.
When using a local address locator, adding the .loc extension after the locator name at the end of the locator path is optional.
This parameter is only active when the Location Type parameter is set to Addresses and the Target Features parameter value is a feature class or layer.
Address Locator
Address Type
(Optional)
Specifies how address fields used by the address locator will be mapped to fields in the input table of addresses.
Specify Single Field if the complete address is stored in one field in the input table, for example, 303 Peachtree St NE, Atlanta, GA 30308. Specify Multiple Fields if the input addresses are divided into multiple fields such as Address, City, State, and ZIP for a general United States address.
  • Multiple Fields—Addresses will be divided into multiple fields.
  • Single Field—Addresses will be contained in one field.
String
Address Fields
(Optional)
The input table fields that correspond to the locator address fields of the address locator.
Some locators support multiple input address fields, such as Address, Address2, and Address3. In this case, the address component can be separated into multiple fields, and the address fields will be concatenated at the time of geocoding. For example, 100, Main st, and Apt 140 across three fields or 100 Main st and Apt 140 across two fields, both become 100 Main st Apt 140 when geocoding.
If you do not map an optional input address field used by the address locator to a field in the input table of addresses, leave the field name blank to indicate that there is no mapping.
This parameter is only active when the Location Type parameter is set to Addresses.
Value table columns:
  • Locator Address Field—The locator address field or fields contained in the address locator.
  • Input Address Field—The input table fields that correspond to the locator address fields.
Value Table
(Optional)
The output table containing a list of invalid records and associated invalidation codes.
Table
Expression
(Optional)
The SQL expression that will be used to select a subset of the input datasets' records. If multiple input datasets are specified, they will all be evaluated using the expression. If no records match the expression for an input dataset, no records from that dataset will be appended to the target.
For more information about SQL syntax, see SQL reference for query expressions used in ArcGIS.
SQL Expression
(Optional)
Specifies whether existing records will be updated in the Target Features parameter value.
  • Checked—Records from the Input Table parameter value will be updated in the Target Features parameter value if they exist there.
  • Unchecked—Records from the Input Table parameter value will be appended to the Target Features parameter value. This is the default.
Boolean
Match Fields
(Optional)
The ID field or fields that will be used to determine matches between the Input Table values and the Target Features values.
This parameter is only active when the Update Existing Target Features parameter is checked.
  • Input ID Field—The name of the input table field containing the ID value.
  • Target ID Field—The name of the target features field containing the ID value to compare to the corresponding input table ID value.
Value Table
Input Table Last Modified Date Field
(Optional)
The field containing the last modified date of the Input Features records.
Date and string field types are supported.
Field
Target Features Last Modified Date Field
(Optional)
The field containing the last modified date of the Target Features records.
This field must be a date field type.
Field
Update Only Matching Features
(Optional)
Specifies whether only existing records will be updated or existing records will be updated and new records will be added.
This parameter is only enabled when the Update Existing Target Features parameter is checked.
  • Checked—Only existing records will be updated.
  • Unchecked—Existing records will be updated and new records will be added. This is the default.
Boolean
(Optional)
Specifies whether the geometry of existing features will be updated.
This parameter is only enabled when the Update Existing Target Features parameter is checked and the Target Features parameter value is a feature class or layer.
  • Checked—The geometry of existing records will be updated when the geometry information from the Input Table parameter value is different than the geometry of the Target Features parameter value. This is the default.
  • Unchecked—The geometry of existing records will not be updated.
Boolean
Field Matching Type
(Optional)
Specifies whether the fields of the input table must match the fields of the target features for data to be appended.
  • Input fields must match target fields—Fields from the input dataset match the fields of the target dataset. Fields that do not match will be ignored. This is the default
  • Use the field map to reconcile field differences—Fields from the input dataset do not need to match the fields of the target dataset. Fields from the input dataset that do not match the fields of the target dataset will not be mapped to the target dataset unless the mapping is explicitly set in the Field Map parameter.
String
Field Map
(Optional)
Controls how the attribute fields from the input table will be transferred or mapped to the target features.
This parameter is only active if the Field Matching Type parameter is set to Use the field map to reconcile field differences.
Because the input table values are appended to an existing target feature that has predefined fields, you cannot add, remove, or change the type of the fields in the field map. You can, however, set merge rules for each output field.
The field map can also be used to combine values from two or more input fields into a single output field.
Field Mappings
Time Format
The format of the input field containing the time values. The type can be short, long, float, double, text, or date. You can either choose a standard time format from the drop-down list or provide a custom format.
The format strings are case sensitive.
  • If the data type of the time field is date, date only, or timestamp offset, no time format is required.
  • If the data type of the time field is numeric (short, long, float, double, or big integer), a list of standard numeric time formats is provided in the drop-down list.
  • If the data type of the time field is string, a list of standard string time formats is provided in the drop-down list. For string fields, you can also specify a custom time format. For example, the time values may have been stored in a string field in one of the standard formats such as yyyy/MM/dd HH:mm:ss or in a custom format such as dd/MM/yyyy HH:mm:ss. For the custom format, you can also specify the a.m. or p.m. designator.
  • For ISO-8601 compliant strings, use yyyy-MM-ddTHH:mm:ss.s as the input format. This input selection can handle inputs that use either a UTC designator (Z) or UTC offsets (±hh:mm).
  • Commonly used formats are listed below:
    • yyyy—Year represented by four digits
    • MM—Month as digits with leading zero for single-digit months
    • MMM—Month as a three-letter abbreviation
    • dd—Day of month as digits with leading zero for single-digit days
    • ddd—Day of week as a three-letter abbreviation
    • hh—Hours with leading zero for single-digit hours and a 12-hour clock
    • HH—Hours with leading zero for single-digit hours and a 24-hour clock
    • mm—Minutes with leading zero for single-digit minutes
    • ss—Seconds with leading zero for single-digit seconds
    • t—One character time marker string, such as A or P
    • tt—Multicharacter time marker string, such as AM or PM
    • unix_us—UNIX time in microseconds
    • unix_ms—UNIX time in milliseconds
    • unix_s—UNIX time in seconds
    • unix_hex—UNIX time in hexadecimal
Learn more about custom dates and time formats
This parameter is only active when the Input Table Last Modified Date parameter value is a text field and the Target Features Last Modified Date Field parameter value is a date field, or the Field Map parameter input value is a text field and the output value is a date field.
String
(Optional)
Specifies whether the date values of the input records will be converted from the time zone of the local system to UTC.
This parameter is only active when the Target Features parameter value is a feature service layer.
  • Checked—The date values of the input records will be converted from the time zone of the local system to UTC. This is the default.
  • Unchecked—The date values of the input records will remain in the time zone of the local system.
Boolean
Derived output
Updated Target Features
The updated target dataset.
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
