An overview of the Standard Feature Analysis toolbox
The Standard Feature Analysis toolbox contains tools for performing spatial analysis on feature data in your portal.
These tools are available when you have an active ArcGIS Enterprise portal that has a hosting server configured for the Feature Analysis - Standard Tools setting. To access and run the tools, you must have spatial analysis privileges. The tools will not work if your active portal is ArcGIS Online.
These tools can be accessed from either the Analysis ribbon or the Portal tab in the Geoprocessing pane.
Toolset |
Description |
The Analyze Patterns toolset contains tools that help you identify, quantify, and visualize spatial patterns in your data. |
The Manage Data toolset contains tools for both the day-to-day management of geographic data and for combining and overlaying data as part of spatial analysis |
The Summarize Data toolset contains tools that calculate total counts, lengths, areas, and basic descriptive statistics of features and their attributes within areas or near other features. |
The Use Proximity toolset contains a tool that helps you answer one of the most common questions posed in spatial analysis: "What is near what?" |
