An overview of the Summarize Data toolset
The Summarize Data toolset contains tools that calculate total counts, lengths, areas, and basic descriptive statistics of features and their attributes within areas or near other features.
These tools are available when you have an active ArcGIS Enterprise portal that has a hosting server configured for the Feature Analysis - Standard Tools setting. To access and run the tools, you must have spatial analysis privileges. The tools will not work if your active portal is ArcGIS Online.
These tools can be accessed from either the Analysis ribbon or the Portal tab in the Geoprocessing pane.
Learn more about portal tools
Tool
Aggregate Points
Uses a layer of point features and a layer of polygon features to identify the points that fall within each polygon's area. After identifying the point-in-polygon spatial relationship, statistics about all points in the polygon are calculated and assigned to the area.
Summarize Nearby
Finds features that are within a specified distance of features in the input layer.
Summarize Within
Finds the point, line, or polygon features (or portions of features) that are within the boundaries of polygons in another layer.
Tools in the Summarize Data toolset
