An overview of the Manage Data toolset
The Manage Data toolset contains tools for both the day-to-day management of geographic data and for combining and overlaying data as part of spatial analysis
These tools are available when you have an active ArcGIS Enterprise portal that has a hosting server configured for the Feature Analysis - Standard Tools setting. To access and run the tools, you must have spatial analysis privileges. The tools will not work if your active portal is ArcGIS Online.
These tools can be accessed from either the Analysis ribbon or the Portal tab in the Geoprocessing pane.
Tool |
Description |
Finds polygons that overlap or share a common boundary and merges them together to form a single polygon. |
Copies all features from two layers into a new layer. The layers that will be combined must contain the same feature types (points, lines, or polygons). You can control how the fields from the input layers are joined and copied. |
Overlays the geometries from multiple layers into one single layer. Overlay can be used to combine, erase, modify, or update spatial features. Overlay is more than a merging of geometries; all the attributes of the features in the overlay are included in the output. |
