Train Text Transformation Model (GeoAI Tools)
Summary
Trains a text transformation model to transform, translate, or summarize text.
Learn more about how Text Transformation works
Usage
  • This tool can also be used to fine-tune an existing trained model.
  • To run this tool using GPU, set the Processor Type environment to GPU. If you have more than one GPU, specify the GPU ID environment instead.
  • The input to the tool is a table or a feature class containing training data, with a text field containing the input text and a label field containing the transformed text.
  • This tool uses transformer-based backbones for training text transformation models and also supports in-context learning with prompts using the Mistral LLM. To install the Mistral backbone, see ArcGIS Mistral Backbone.
  • For information about requirements for running this tool and issues you may encounter, see Deep Learning frequently asked questions.
Parameters
Label Explanation Data type
Input Table
A feature class or table containing a text field with the input text for the model and a label field containing the target transformed text.
Feature Layer; Table View
Text Field
A text field in the input feature class or table that contains the input text that will be transformed by the model.
Field
Label Field
A text field in the input feature class or table that contains the target transformed text for training the model.
Field
Output Model
The output folder location where the trained model will be stored.
Folder
Pretrained Model File
(Optional)
A pretrained model that will be used to fine-tune the new model. The input can be an Esri model definition file (.emd) or a deep learning package file (.dlpk).
A pretrained model that performs a similar task can be fine-tuned to fit the training data. The pretrained model must have been trained with the same model type and backbone model that will be used to train the new model.
File
Max Epochs
(Optional)
The maximum number of epochs for which the model will be trained. A maximum epoch value of 1 means the dataset will be passed through the neural network one time. The default value is 5.
Long
Model Backbone
(Optional)
Specifies the preconfigured neural network that will be used as the architecture for training the new model.
  • t5-small—The new model will be trained using the T5 neural network. T5 is a unified framework that converts every language problem into a text-to-text format. t5-small is the small variant of T5.
  • t5-base—The new model will be trained using the T5 neural network. T5 is a unified framework that converts every language problem into a text-to-text format. t5-base is the medium variant of T5.
  • t5-large—The new model will be trained using the T5 neural network. T5 is a unified framework that converts every language problem into a text-to-text format. t5-large is the large variant of T5.
  • mistral—The model will be trained using the Mistral large language model (LLM). Mistral is a decoder-only transformer that uses Sliding Window Attention, Grouped Query Attention, and the Byte-fallback BPE tokenizer. To install the Mistral backbone, see ArcGIS Mistral Backbone.
String
Batch Size
(Optional)
The number of training samples that will be processed at one time. The default value is 2.
Increasing the batch size can improve tool performance; however, as the batch size increases, more memory is used. If an out of memory error occurs, use a smaller batch size.
Double
Model Arguments
(Optional)
Additional arguments that will be used for initializing the model. The supported model argument is Sequence Length, which is used to set the maximum sequence length of the training data that will be considered for training the model.
Value table columns:
  • Name—The name of the function argument.
  • Value—The value of the function argument.
Value Table
Learning Rate
(Optional)
The step size indicating how much the model weights will be adjusted during the training process. If no value is specified, an optimal learning rate will be derived automatically.
Double
Validation Percentage
(Optional)
The percentage of training samples that will be used for validating the model. The default value is 10 for transformer-based model backbones and 50 for the Mistral backbone.
Double
Stop when model stops improving
(Optional)
Specifies whether model training will stop when the model is no longer improving or continue until the Max Epochs parameter value is reached.
  • Checked—The model training will stop when the model is no longer improving, regardless of the Max Epochs parameter value. This is the default.
  • Unchecked—The model training will continue until the Max Epochs parameter value is reached.
Boolean
Make model backbone trainable
(Optional)
Specifies whether the backbone layers in the pretrained model will be frozen, so that the weights and biases remain as originally designed.
  • Checked—The backbone layers will not be frozen, and the weights and biases of the Model Backbone parameter value can be altered to fit the training samples. This takes more time to process but typically produces better results. This is the default.
  • Unchecked—The backbone layers will be frozen, and the predefined weights and biases of the Model Backbone parameter value will not be altered during training.
Boolean
Remove HTML Tags
(Optional)
Specifies whether HTML tags will be removed from the input text.
  • Checked—The HTML tags in the input text will be removed. This is the default.
  • Unchecked—The HTML tags in the input text will not be removed.
Boolean
Remove URLs
(Optional)
Specifies whether URLs will be removed from the input text.
  • Checked—The URLs in the input text will be removed. This is the default.
  • Unchecked—The URLs in the input text will not be removed.
Boolean
Prompt
(Optional)
A specific input or instruction given to a large language model (LLM) to generate an expected output.
The default value is Transform the input text from the text field into the transformed text present in the label field.
String
Environments
Processor Type, GPU ID
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Yes
