Create Composite Address Locator (Geocoding Tools)
Summary
Creates a composite locator. A composite locator consists of two or more individual locators that allow addresses and places to be matched using multiple locators.
Learn more about composite locators
Usage
  • Before creating composite locators, use the Create Locator tool or Create Feature Locator tool to create participating locators.
  • Spatial reference for a composite locator is required. The spatial reference of the first participating locator is used unless you specify a different output coordinate system in the tool's environment settings.
  • Use the Order by role and score option for the Result Order parameter for a multirole locator, an ArcGIS StreetMap Premium locator (for example), and several single role locators. This option orders the locators and roles into an optimal fallback order.
  • To generate the correct Python syntax for the in_result_ordering parameter, first run the tool from the Geoprocessing pane using the appropriate Result Order parameter option. Then open the Run menu, and select Copy Python Command.
Parameters
Label Explanation Data type
Address Locators
The locators that will be used to create the composite locator. The order of the participating locators determines how candidates are searched and a place or address is matched. When you geocode a single place or address, the place or address will be matched using all participating locators unless the locator is specified with a selection criterion. All the found candidates will be displayed based on the order of the listed participating locators. If you geocode a table of addresses or places, addresses or places will be matched automatically to the first best candidate found from the first participating locators. If the address or place fails to match, it will fall back to the subsequent locator in the list.
A reference name for each participating locator is required. This is the name of the locator referred to by the composite locator. Do not use spaces or special symbols in the name. The maximum length of the name is 14 characters.
Value table columns:
  • Participating Address Locators—The participating address locators.
  • Name—A reference name for each participating locator is required.
Value Table
Field Map
The mapping of input fields used by each participating locator to the input fields of the composite locator.
This includes the fields and field contents that are generated by the participating locators. Each unique input field is listed in the Field Map parameter. On the left in the Input Fields column, is a list of all the input fields for the composite locator. When you select a field, you can view the fields from each participating locator that are mapped to that field under the Subfield and Properties columns. These fields are the input fields for the composite locator.
Caution:
Do not delete any locator fields from the Field Map parameter. A composite locator created without all locator fields is invalid.
Field Mappings
Selection criteria
(Optional)
The selection criteria for each participating locator. Only one selection criterion is supported for each participating locator.
When building a composite locator, you can specify which locators are used based on the values of input address fields. For example, if the composite locator uses a locator that contains street data for a specific city, you can filter out any addresses or places that do not have that city name. Using selection criteria will disqualify participating locators that do not meet the criteria for a particular address so that the geocoding process will be more efficient. For example, if a street address locator is specified with a selection criterion as "City" = 'Atlanta', only addresses that contain the city name Atlanta will be geocoded using this locator.
The selection criteria is used when a table of addresses with multiple input address fields is geocoded. They do not apply when geocoding a table with the addresses in a single field or when finding addresses in a single-line input in the Locate pane.
To specify a selection criterion, check the locator check box under the Selection Criteria column that you want to apply the criterion to. You can enter an expression such as "City" = 'Atlanta' in the text box, or click the more button to open the Specify Locator Selection Criteria dialog box and define the criteria.
  • Address Locators—The participating locators.
  • Selection Criteria—Selection criteria for each participating locator.
Value Table
Output Composite Address Locator
The composite address locator that will be created. ArcGIS Pro only supports saving locators in a file folder.
Address Locator
Result Order
(Optional)
Specifies the fallback order of the participating locators to which addresses can be matched to increase the probability of finding the best match when geocoding.
  • Use locator order—Participating locators will be in the order they were added and adhere to the fallback order described in Combine multiple locators into a composite locator. This is the default.
  • Order by role and score—Individual roles of participating locators will be grouped and ordered from most to least precise. Results will be returned for more precise roles first followed by less precise roles, and for results that are returned for different locators with the same role, results will be returned based on score. It is recommended that you use this option if you have a multirole locator and several single role locators or if you have more than one multirole locator. This automatically orders the locators and roles into a recommended, optimal fallback order.
  • Custom order—A customizable fallback order for participating locators will be used that allows you to insert locators between the roles of a multirole locator.
String
Environments
Output CONFIG Keyword, Output Coordinate System
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
