Rebuild Address Locator (Geocoding Tools)
Summary
Rebuilds an address locator to update the locator with the current reference data. Because a locator contains a snapshot of the reference data when it was created, it will not geocode addresses with the updated data when the geometry and attributes of the reference data are changed. To geocode addresses with the current version of the reference data, the locator must be rebuilt to update the changes in the locator.
Usage
  • You must have write privileges to the address locator to use this tool.
  • To rebuild a locator, all the referenced feature classes and tables must exist. Rebuilding the locator will fail if you moved the reference data to another location since the last time the locator was created. Alternatively, a locator can be re-created using the Create Locator tool.
  • Locators based on a versioned geodatabase will be rebuilt with the same version used when the locator was created.
  • Composite locators cannot be rebuilt using this tool. The best practice for managing composite locators is to create a composite locator using the Create Composite Address Locator tool in a geoprocessing model. In ModelBuilder, this tool can be chained with the Create Locator tool to use its outputs as the inputs to the composite locator and manage the entire process of creating or updating a composite locator.
Parameters
Label Explanation Data type
Input Address Locator
The address locator that will be rebuilt.
Address Locator
Derived output
Rebuilt Address Locator
The rebuilt address locator.
Address Locator
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
