Detect Control Points (Image Analyst Tools)
Summary
Detects ground control points in a mosaic dataset.
Usage
  • This tool is used as part of the orthorectification process. The preliminary image collection is created using the Reality Mapping workspace. The mosaic dataset requires a quick adjustment; then the image collection can be further refined using control points.
  • The tool will perform object detection on the images to find the ground control points (GCP).
  • This tool can detect two types of ground control markers: checkers and crosses.
  • The results of the detections can be used in ArcGIS Reality for ArcGIS Pro projects.
  • The tool uses two deep learning models trained by Esri. For more information about deep learning, see Deep learning using the ArcGIS Image Analyst extension.
  • To set up your machine to use deep learning frameworks in ArcGIS Pro, see Install deep learning frameworks for ArcGIS.
  • While the tool supports both CPU and GPU, a NVIDIA CUDA-capable GPU with a minimum of 4 GB VRAM is required, and 8 GB VRAM is recommended. For the latest GPU requirements, see Deep learning frequently asked questions.
  • This tool supports and uses multiple GPUs if available. To use a specific GPU, specify the GPU ID environment. When the GPU ID environment is not set, the tool will use all available GPUs; this is the default.
Parameters
Label Explanation Data type
Input Mosaic Dataset
The mosaic dataset that contains the source imagery from which the ground control points will be created.
Mosaic Dataset; Mosaic Layer
Input Control Points
The input control point set that contains a list of ground control point features.
File; Feature Class; Feature Layer; String
Output Control Points
The output ground control point features.
Feature Class
Output Folder Image Chips
(Optional)
The output folder of image chips.
Folder
Cropped Image Size
(Optional)
The tile size of the output image chips.
The default tile size is 1024.
Long
Number of Tie Points
(Optional)
The number of tie points for each ground control point.
The default is 5.
Long
Environments
Current Workspace, Geographic Transformations, GPU ID, Output Coordinate System, Processor Type, Scratch Workspace
Licensing information
  • Basic: Requires Image Analyst or ArcGIS Reality for ArcGIS Pro
  • Standard: Requires Image Analyst or ArcGIS Reality for ArcGIS Pro
  • Advanced: Requires Image Analyst or ArcGIS Reality for ArcGIS Pro
