Square Root (Image Analyst Tools)
Summary
Calculates the square root of the cell values in a raster.
Illustration
Square Root illustration
OutRas = SquareRoot(InRas1)
Usage
  • Input values that are less than 0 will be NoData in the output raster.
  • The output raster from this tool is always floating-point type, regardless of the input value type.
  • If the input is a multiband raster, the output will be a multiband raster. The tool will perform the operation on each band in the input.
  • If the input is multidimensional raster data, all slices from all variables will be processed. The output will be a multidimensional raster in CRF format.
Parameters
Label Explanation Data type
Input raster or constant value
The input values to find the square root of.
To use a number as an input for this parameter, the cell size and extent must first be set in the environment.
Raster Layer; Constant
Return value
Output raster
The output raster.
The cell values are the square root of the input cell values.
Raster
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Image Analyst or Spatial Analyst
  • Standard: Requires Image Analyst or Spatial Analyst
  • Advanced: Requires Image Analyst or Spatial Analyst
