An overview of the Math toolset in Image Analyst
Available with Image Analyst license.
Available with Spatial Analyst license.
The Math toolset contains tools that perform mathematical operations on rasters.
The tools are grouped into four main categories:
  • Math
    The tools at the top level of the math toolset perform basic mathematical operations on rasters in the following categories: Arithmetic, Power, Exponential, and Logarithmic. Also included are tools that alter the sign of the raster values, as well as those involved in converting the values between integer and floating point.
  • Conditional
    The Conditional math toolset allows you to control the output values based on the conditions placed on the input values.
  • Logical
    The Logical math toolset contains tools for performing logical evaluations on rasters in the following categories: Bitwise, Boolean, Combinatorial, Relational, and Conditional.
  • Trigonometric
    The Trigonometric math toolset contains tools for trigonometric calculations in several categories: Regular, Inverse, Hyperbolic, and Inverse Hyperbolic.
License:
The Math tools are also available if you have a Spatial Analyst extension license.
Certain Math tools are also available with a 3D Analyst extension license. These tools are: Divide, Float, Int, Minus, Plus, and Times.
The following table lists the available Math toolsets and provides a brief description of each.
Tool
General Math toolset
The general Math tools apply a mathematical function to the input. These tools fall into several categories. The arithmetic tools perform basic mathematical operations, such as addition and multiplication. There are tools that perform various types of exponentiation operations, which includes exponentials and logarithms in addition to the basic power operations. The remaining tools are used either for sign conversion or for conversion between integer and floating point data types.
Conditional Math toolset
The Conditional Math tools allow you to control the output values based on the conditions placed on the input values. The conditions that can be applied are of two types, those being either queries on the attributes or a condition based on the position of the conditional statement in a list.
Logical Math toolset
The Logical Math tools evaluate the values of the inputs and determine the output values based on a defined logic. The tools are grouped into four main categories: Bitwise, Boolean, Combinatorial, Logical, and Relational.
Trigonometric Math toolset
Trigonometric Math tools perform various trigonometric calculations on the values in an input raster.
The Math toolsets
The following applies only to the tools at the top level of this toolset. For more details on the others, go to the appropriate sections for the Conditional, Logical and Trigonometric mathematical operations.
Certain tools require two inputs:
  • Arithmetic: Plus, Minus, Times, Divide, Mod (modulus)
  • Power: Power
While other tools only need a single input:
  • Exponential: Exp, Exp2, Exp10
  • Logarithmic: Ln, Log2, Log10
  • Power: Square, Square Root
  • Sign: Abs, Negate
  • Type conversion: Float, Int, Round Down, Round Up
The following table lists the available general Math tools and provides a brief description of each:
Tool
Abs
Calculates the absolute value of the cells in a raster.
Divide
Divides the values of two rasters on a cell-by-cell basis.
Exp
Calculates the base e exponential of the cells in a raster.
Exp10
Calculates the base 10 exponential of the cells in a raster.
Exp2
Calculates the base 2 exponential of the cells in a raster.
Float
Converts each cell value of a raster into a floating-point representation.
Int
Converts each cell value of a raster to an integer by truncation.
Ln
Calculates the natural logarithm (base e) of cells in a raster.
Log10
Calculates the base 10 logarithm of cells in a raster.
Log2
Calculates the base 2 logarithm of cells in a raster.
Minus
Subtracts the value of the second input raster from the value of the first input raster on a cell-by-cell basis.
Mod
Finds the remainder (modulo) of the first raster when divided by the second raster on a cell-by-cell basis.
Negate
Changes the sign (multiplies by -1) of the cell values of the input raster on a cell-by-cell basis.
Plus
Adds (sums) the values of two rasters on a cell-by-cell basis.
Power
Raises the cell values in a raster to the power of the values found in another raster.
Round Down
Returns the next lower integer value, just represented as a floating point, for each cell in a raster.
Round Up
Returns the next higher integer value, just represented as a floating point, for each cell in a raster.
Square
Calculates the square of the cell values in a raster.
Square Root
Calculates the square root of the cell values in a raster.
Times
Multiplies the values of two rasters on a cell-by-cell basis.
Tools in the general Math toolset
