Train Random Trees Classifier (Image Analyst Tools)
Summary
Generates an Esri classifier definition file (.ecd) using the Random Trees classification method.
The random trees classifier is an image classification technique that is resistant to overfitting and can work with segmented images and other ancillary raster datasets. For standard image inputs, the tool accepts multiband imagery with any bit depth, and it will perform the Random Trees classification on a pixel basis or segment, based on the input training feature file.
Usage
  • The Random Trees classification method is a collection of individual decision trees in which each tree is generated from different samples and subsets of the training data. The idea behind calling these decision trees is that for every pixel that is classified, a number of decisions are made in rank order of importance. When you graph these for a pixel, it looks like a branch. When you classify the entire dataset, the branches form a tree. This method is called random trees because you are actually classifying the dataset a number of times based on a random subselection of training pixels, resulting in many decision trees. To make a final decision, each tree has a vote. This process works to mitigate overfitting. The Random Trees classification method is a supervised machine-learning classifier based on constructing a multitude of decision trees, choosing random subsets of variables for each tree, and using the most frequent tree output as the overall classification. The Random Trees classification method corrects for the decision trees' propensity for overfitting to their training sample data. With this method, a number of trees are grown—by an analogy, a forest—and variation among the trees is introduced by projecting the training data into a randomly chosen subspace before fitting each tree. The decision at each node is optimized by a randomized procedure.
  • For segmented rasters that have their key property set to Segmented, the tool computes the index image and associated segment attributes from the RGB segmented raster. The attributes are computed to generate the classifier definition file to be used in a separate classification tool. The attributes for each segment can be computed from any Esri-supported image.
  • Any Esri-supported raster is accepted as input, including raster products, segmented rasters, mosaics, image services, and generic raster datasets. Segmented rasters must be 8-bit rasters with 3 bands.
  • To create the training sample file, use the Training Samples Manager pane from the Classification Tools drop-down menu.
  • The Segment Attributes parameter is only active if one of the raster layer inputs is a segmented image.
  • To classify time series raster data using the Continuous Change Detection and Classification (CCDC) algorithm, first run the Analyze Changes Using CCDC tool. Then use the output change analysis raster as the input raster for this training tool.
    The training sample data must have been collected at multiple times using the Training Samples Manager. The dimension value for each sample is listed in a field in the training sample feature class, which is specified in the Dimension Value Field parameter.
Parameters
Label Explanation Data type
Input Raster
The raster dataset to classify.
You can use any Esri-supported raster dataset. One option is a 3-band, 8-bit segmented raster dataset in which all the pixels in the same segment have the same color. The input can also be a single band, 8-bit, grayscale segmented raster.
Raster Layer; Mosaic Layer; Image Service; String
Input Training Sample File
The training sample file or layer that delineates the training sites.
These can be either shapefiles or feature classes that contain the training samples. The following field names are required in the training sample file:
  • classname—A text field indicating the name of the class category
  • classvalue—A long integer field containing the integer value for each class category
Feature Layer
Output Classifier Definition File
A JSON file that contains attribute information, statistics, or other information for the classifier. An .ecd file is created.
File
Additional Input Raster
(Optional)
Ancillary raster datasets, such as a multispectral image or a DEM, will be incorporated to generate attributes and other required information for classification. This parameter is optional.
Max Number of Trees
(Optional)
The maximum number of trees in the forest. Increasing the number of trees will lead to higher accuracy rates, although this improvement will level off eventually. The number of trees increases the processing time linearly.
Long
Max Tree Depth
(Optional)
The maximum depth of each tree in the forest. Depth is another way of saying the number of rules each tree is allowed to create to come to a decision. Trees will not grow any deeper than this setting.
Long
Max Number of Samples Per Class
(Optional)
The maximum number of samples that will be used to define each class.
The default value of 1000 is recommended when the inputs are nonsegmented rasters. A value that is less than or equal to 0 means that the system will use all the samples from the training sites to train the classifier.
Long
Segment Attributes
(Optional)
Specifies the attributes that will be included in the attribute table associated with the output raster.
This parameter is only active if the Segmented key property is set to true on the input raster. If the only input to the tool is a segmented image, the default attributes are Converged color, Count of pixels, Compactness, and Rectangularity. If an Additional Input Raster value is included as an input with a segmented image, Mean digital number and Standard deviation are also available attributes.
  • Converged color—The RGB color values will be derived from the input raster on a per-segment basis. This is also known as average chromaticity color.
  • Mean digital number—The average digital number (DN) will be derived from the optional pixel image on a per-segment basis.
  • Standard deviation—The standard deviation will be derived from the optional pixel image on a per-segment basis.
  • Count of pixels—The number of pixels composing the segment, on a per-segment basis.
  • Compactness—The degree to which a segment is compact or circular, on a per-segment basis. The values range from 0 to 1, in which 1 is a circle.
  • Rectangularity—The degree to which the segment is rectangular, on a per-segment basis. The values range from 0 to 1, in which 1 is a rectangle.
String
(Optional)
Contains dimension values in the input training sample feature class.
This parameter is required to classify a time series of raster data using the change analysis raster output from the Analyze Changes Using CCDC tool.
Field
Environments
Current Workspace, Extent, Geographic Transformations, Output Coordinate System, Scratch Workspace, Snap Raster
Licensing information
  • Basic: Requires Image Analyst or Spatial Analyst
  • Standard: Requires Image Analyst or Spatial Analyst
  • Advanced: Requires Image Analyst or Spatial Analyst
