Use Training Samples Manager
Available with Image Analyst license.
Available with Spatial Analyst license.
In supervised image classification, you must train the classifier to assign pixels or objects to a given class using training samples. The class categories are determined by the classification schema, and the training samples can be generated using the Training Samples Manager pane. Tools in the Training Samples Manager pane allow you to create training samples for each class category in the schema and provide information about the number and size of samples to help you improve the accuracy of the classification model.
The Training Samples Manager is in the Classification Tools drop-down menu in the Image Classification group on the Imagery tab. Select the raster dataset you want to classify in the Contents pane to display the Imagery tab, and be sure you are working in a 2D map. The Classification Tools menu is unavailable if the active map is a 3D scene, or if the highlighted image is not a multiband image.
The Training Samples Manager is also displayed in the classification wizard workflow and operates in the same manner as described below.
Manage the classification schema
When you open the Training Samples Manager pane, the schema management section is at the top with the default classification schema from the 2011 National Land Cover Database (NLCD2011). If the classification schema is only moderately different from the NLCD2011 schema, you can add or remove individual classes from this schema and save it as a new schema. Right-click any of the classes to add classes or edit the class properties, such as the name, value, color, and alias. You can also load an existing schema or create a schema and save it.
Edit schemas before collecting training samples. If a class is edited after samples in another class have been collected, temporarily switch to a different sketch tool to preserve edits to the class.
The following table lists the tools you can use to manage the classification schema:
Tool
Function
Point
Create a training sample by drawing a point over pixels or objects in the raster.
New Rectangle
Create a training sample by drawing a rectangle around pixels or objects in the raster.
New Polygon
Create a training sample by drawing a polygon around pixels or objects in the raster.
New Circle
Create a training sample by drawing a circle around pixels or objects in the raster.
New Lasso Area
Create a training sample by drawing a freehand shape around pixels or objects in the raster.
Select By Polygon
Create a training sample by selecting a segment from a segmented layer. This option is only available if there is a segmented layer in the Contents pane. Activate the Segment Picker tool by highlighting the segmented layer in the Contents pane, and select the layer from the Segment Picker drop-down list.
New Template
Create a classification schema. Right-click the New Schema title and click Add New Class to begin creating class categories.
Browse
Select a classification schema option.
  • Browse to an existing schema.
  • Generate a schema from an existing training sample feature class.
  • Generate a schema from an existing classified raster.
  • Use the default 2011 National Land Cover Database schema.
Save
Save changes to the schema.
Save Edits
Save a new copy of the schema.
Add
Add a class category to the schema. Select the name of the schema first to create a parent class at the highest level. Select the name of an existing class to create a subclass.
Delete Selected Item(s)
Remove the selected class or subclass category from the schema.
Create Scatter Plot Matrix
Use a scatter plot matrix to create a grid of scatter plots visualizing bivariate relationships between combinations of multiple numeric variables.
If the training samples represent different classes, their scatter plots should not overlap.
Create Histogram
Use a histogram to visualize the distribution of values in a numeric variable by grouping numbers into bins and measuring the frequency of those groups.
If the training samples represent different classes, their histograms should not overlap.
Create training samples
To create the training samples, complete the following steps:
  1. Load the classification schema you want to use in the schema manager at the top of the Training Samples Manager pane using the Classification Schema button , add or remove class categories if you want to make modifications, and save any changes you make to the schema.
  2. Select the class that you want to collect training samples for from the list of classes in the schema manager.
  3. Click one of the sketch tools, or use the segment picker to begin collecting training samples.
    1. To use the Segment Picker tool, the segmented image must be loaded into the Contents pane. Click the drop-down arrow to select the segmented layer that you want to collect training samples from.
    2. Click a segment in the map to add it as a training sample.
  4. Using a sketch tool, delineate the image feature representing the class on the map, and collect a representative number of training samples for each class in the schema.
  5. Add, delete, and organize the training samples using the tools in the bottom section of the pane.
  6. Once you are satisfied with the training samples, click the Save button to save the results.
Manage the training samples
The bottom section of the pane displays and manages the training samples you collected for each class. Collect representative sites, or training samples, for each land cover class in the image. A training sample has location information (polygon) and an associated land cover class. The image classification algorithm uses the training samples, saved as a feature class, to identify the land cover classes in the entire image.
You can view and manage training samples by adding, grouping, or removing them. When you select a training sample, it is selected on the map. Double-click a training sample in the table in the Training Samples Manager pane to zoom to it on the map.
The following table lists the tools you can use when working with training samples:
Tool
Function
Browse
Open an existing training samples feature class.
Save
Save edits made to the current training samples feature class.
Save Edits
Save the current training samples as a new feature class.
Edit class properties
Edit the properties of the current class.
Collapse
Collapse multiple training samples into a single multipart training sample. This can be useful to see the total number of samples for each class category and assess the distribution of sample sizes for each class or to delete a large group of training samples at once.
Split
Expand a multipart training sample into its individual component features. Each training sample becomes its own polygon.
Duplicate Section
Duplicate the selected record for the slice in the multidimensional raster layer that is currently being displayed. This is useful for generating training samples for multiple time slices if the sample class has not changed over time.
This tool is only activated if the raster being sampled is a multidimensional raster layer.
Delete the selected training samples.
The training samples table in this portion of the Training Samples Manager pane lists the number of samples and the percentage of pixels representing each class. If you used the Segment Picker tool to collect the training samples, the number of samples is the number of segments you selected to define the class. This is important to keep in mind when you use a statistical classifier such as Maximum Likelihood, because the number of segments represents the total number of samples. For example, if eight segments were collected as training samples for a class, it may not be a statistically significant number of samples for reliable classification. However, if you collected the same training samples as pixels, the training sample can be represented by hundreds or thousands of pixels, which is a statistically significant number of samples. The number and percentage of training samples is less important when using the nonparametric machine-learning classifiers such as Random Trees and Support Vector Machine.
Collect time information in samples
The Training Samples Manager supports the collection of time information for each training sample when the raster being sampled is a multidimensional raster or multidimensional mosaic dataset. If the Multidimensional Info tab includes information for a time series of raster images, training samples can be collected for each slice in the dataset, and the slice's time information will be automatically generated in the training sample attributes.
To collect time information in samples, complete the following steps:
  1. Click the StdTime drop-down menu in the Current Display Slice group on the Multidimensional tab to display the slice for which you want to collect samples.
    For more information, see Multidimensional tab.
  2. In the Training Samples Manager pane, select the class that you want to collect training samples for from the list of classes in the schema manager.
  3. Click one of the sketch tools, and delineate the image feature representing the class on the map.
  4. If a sample persists multiple times in the multidimensional raster layer, you can duplicate it across multiple time slices as follows:
    1. Select the sample in the table.
    2. Use the controls in the Current Display Slice group to switch the display to the new time slice.
    3. Click the Duplicate for Current Display Slice button in the Training Samples Manager to create a copy of the sample with a time value matching that of the current slice.
      You can collapse multiple samples from the same class and the same time into a single record, and duplicate the collapsed record to copy all the training samples to a new time slice.
