Generate Calibration Points (Linear Referencing Tools)
Summary
Generates calibration points for any route shape provided, including complex shapes such as self-closing, self-intersecting, and branched routes.
Usage
An LRS dataset is required to run this tool.
The Input Polyline Features parameter value is the basis for the calibration points that will be generated.
The Calibration Point Feature Class parameter value must be registered with the LRS.
The LRS Network parameter value must be registered with the LRS.
Derived LRS Networks are not supported as the LRS Network parameter value.
Z-values are considered when calculating the geometric length of the centerlines.
Gap calibration rules will be followed while generating calibration points using the Geometry length and Attribute fields options for the Calibration Method parameter.
If the Calibration Method parameter is set to M on route, m-values will be used at the start vertex and end vertex of the input routes to create beginning and ending calibration points.
When the Calibration Method parameter is set to Attribute fields, the following occur:
The Attribute fields option will be used to evaluate fields with a Double field type for calibration.
The From Measure Field parameter value will be used to provide the from measure of the route and the To Measure Field parameter value will be used to provide the to measure of the route.
The Input Polyline Features parameter value can be a feature service layer that does not have the linear referencing capability. If the Calibration Point Feature Class parameter value is a feature service layer, it must have the linear referencing capability enabled.
Parameters
| Label | Explanation | Data type |
Input Polyline Features |
The features that will be used as the source to calculate the measure values for calibration points. |
Feature Layer |
Route ID Field |
The field containing values that uniquely identify each route. The field type must match the |
Field |
From Date Field |
The field containing the from date values of a route. |
Field |
To Date Field |
The field containing the to date values of a route. |
Field |
Calibration Point Feature Class |
The existing calibration point feature class to which new features will be added. |
Feature Layer |
LRS Network |
The LRS Network for which the measure values will be generated in the calibration points feature class. |
String |
Calibration Direction (Optional) |
Specifies the direction of increasing calibration on a route when creating calibration points.
String |
Calibration Method (Optional) |
Specifies the method that will be used to determine the measures on a route when creating calibration points.
String |
From Measure Field (Optional) |
The field containing the from measure for the selected route. This parameter is active when the Calibration Method parameter is set to Attribute fields. |
Field |
To Measure Field (Optional) |
The field containing the to measure for the selected route. This parameter is active when the Calibration Method parameter is set to Attribute fields. |
Field |
Derived output
Updated Calibration Point Feature Class |
The updated calibration features. |
Feature Layer |
Output Details File |
A text file that details changes made by the tool. |
Text File |
Environments
Current Workspace, Parallel Processing Factor
Special cases
- Parallel Processing Factor
The default value for this environment, if left blank, is 0%. Any absolute value for the environment is always clamped between 0 and the number of logical cores in that machine.
Licensing information
- Basic: Requires ArcGIS Linear Referencing
- Standard: Requires ArcGIS Linear Referencing
- Advanced: Requires ArcGIS Linear Referencing
