Get Field Value (Model Tools)
Summary
Returns the value of the first row of a table for the specified field.
Usage
This tool is only available from ModelBuilder for use in models. The tool is not available from the Geoprocessing pane or from Python.
This tool differs from the Iterate Field Value tool as only the first row of the input table is read, and the value of the specified field in this row becomes the output.
Parameters
| Label | Explanation | Data type |
Input Table |
The input table to get the value from. |
Table View; Raster Layer |
Field |
The input field to get the value from. The value of the first record will be output. |
Field |
Data type (Optional) |
The data type of the output. |
String |
Null Value (Optional) |
The value to use for null values. The default is 0 for numbers and blank ("") for strings. |
String |
Derived output
Value |
The value of the first row of a table for the specified field. |
Any Value |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
