An overview of ModelBuilder tools
ModelBuilder contains a collection of utility tools that support building flexible and powerful models.
Iterators
Iterator tools enable batch processing and repeat a process or set of processes on a set of inputs.
Tool
For
Iterates over a starting and ending value by a given value.
Iterate Datasets
Iterates over different types of datasets in a workspace.
Iterate Feature Classes
Iterates over feature classes in a workspace or feature dataset.
Iterate Feature Selection
Iterates over features in a feature class.
Iterate Field Values
Iterates each value in a field.
Iterate Fields
Iterates fields in a table.
Iterate Files
Iterates over files in a folder.
Iterate Layers
Iterates layers in a map.
Iterate Multivalue
Iterates over a list of values.
Iterate Rasters
Iterates over rasters in a workspace.
Iterate Row Selection
Iterates over rows in a table.
Iterate Tables
Iterates over tables in a workspace.
Iterate Time
Iterates over time in a date field.
Iterate Workspaces
Iterates over workspaces in a folder.
While
Iterates until a condition becomes true or until a condition comes false.
Utilities
Utility tools include operations for extending the capabilities of a model.
Tool
Calculate Value
Returns a value based on a specified Python or ArcGIS Arcade expression.
Collect Values
Collects output values from an iterator or converts a list of values into a single input with multiple values.
Custom Message
Adds custom error, warning, or informative messages to a model's messages to enhance the context of a model when run.
Get Field Value
Returns the value of the first row of a table for the specified field.
Parse Path
The Parse Path tool parses the input into its file, path, name, or extension. The output can be used as inline variable in the output name of other tools.
Select Data
Selects data in a parent data element such as a folder, geodatabase, or feature dataset.
Logical
Logical tools control the flow of processes in a model and enable if-then-else branching logic.
Tool
If Coordinate System Is
Evaluates the input data for the specified coordinate system.
If Data Exists
Evaluates whether the specified data exists.
If Data Type Is
Evaluates whether the input data matches the specified data type.
If Expression Is
Evaluates whether a given Python expression is True or False.
If Feature Type Is
Evaluates whether a feature class is of the specified feature type.
If Field Exists
Evaluates if the input data has the specified fields.
If Field Value Is
Evaluates if the values in an attribute field match a specified value, expression, or second field.
If Row Count Is
Evaluates the row count of the input data and checks whether it matches a specified value.
If Selection Exists
Checks whether the input data includes a selection and whether a certain number of records are selected.
If Spatial Relationship Is
Evaluates whether the inputs have a specified spatial relationship.
If Value Is
Evaluates an input value compared to a single value, a list of values, or a range of values using a defined comparison operator.
Merge Branch
Merges two or more logical branches into a single output.
Stop
Exits a model out of the iteration loop if the input values are set to true or set to false. For the set of input values, iteration will continue if all the inputs are true and stop if any one of the inputs is false. It is functionally similar to the While tool but is useful to stop a model if there is already one While iterator in a model and no additional iterators can be added.
