Parse Path (Model Tools)
Summary
Parses an input into its file name, extension, path, and the last workspace name. The output can be used as an inline variable in the output name of other tools.
Learn how Parse Path works in ModelBuilder
Usage
  • This tool is only available from ModelBuilder for use in models. The tool is not available from the Geoprocessing pane or from Python.
  • More than one variable name can be added to create unique names for the output, for example, C:\Temp\Out_%Name%_%Workspace Name%.
  • If the input to this tool is C:\1Tool Data\City Roads.shp, for example, it will be parsed into the following outputs:
    Parse
    Result
    Path
    C:\1Tool Data
    Name
    City Roads
    Extension
    shp
    Workspace Name
    1Tool Data
    If the Format The name, extension and workspace parameter is checked, the path above will be parsed into the following outputs:
    Parse
    Result
    Path
    C:\1Tool Data
    Name
    City_Roads
    Extension
    shp
    Workspace Name
    _1Tool_Data
  • The same functionality can be accessed in scripting with the Python os module. For example, if you pass the following input variable:
    inData = r"C:\1Tool Data\City Roads.shp", then
    • To get the name City Roads
      import os
      name = os.path.basename(inData)
    • To get the path C:\1Tool Data
      import os
      path = os.path.dirname(inData)
    • To get the file extension shp
      import os
      ext = os.path.splitext(inData)[1][1:]
    • To get the workspace name 1Tool Data
      import os
      folder = os.path.basename(os.path.dirname(inData))
    To parse paths in a similar way to when the Format Name, Extension and Workspace parameter is checked, do the following:
    • To get the name City_Roads
      import os
      import re
      name = re.sub('[^0-9a-zA-Z]+', '_', name)
      if name[0].isdigit():
          name = "_" + name
      import os
      import os
    • To get the workspace name _1Tool_Data
      import os
      import re
      folder = re.sub('[^0-9a-zA-Z]+', '_', folder)
      if folder[0].isdigit():
          folder = "_" + folder
  • The Path output of this tool has a workspace data type and can be connected directly as an input to the Create Feature Class tool's Feature Class Location parameter, which accepts a workspace data type as input. For tools such as Copy that do not have a workspace data type parameter, the Path value can be passed to the tool using inline variable substitution such as %Path%\Out_%Name%.%Extension%.
    Parse Path with the Create Feature Class tool
Parameters
Label Explanation Data type
Input Values
The input values that will be parsed.
Any Value
Format the name, extension and workspace
(Optional)
Specifies whether all reserved characters will be removed.
  • Checked—Reserved characters will be removed.
  • Unchecked—Reserved characters will not be removed. This is the default.
Boolean
Derived output
Path
The workspace of the input.
Workspace
Name
The file name, excluding the extension.
String
Extension
The file extension.
String
Workspace Name
The name of the workspace.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
