If Feature Type Is (Model Tools)
Summary
Evaluates whether a feature class is of the specified feature type.
Learn how If Feature Type Is works in ModelBuilder
Usage
  • This tool is only available from ModelBuilder for use in models. The tool is not available from the Geoprocessing pane or from Python.
  • The tool has two Boolean outputs, True and False. Based on the condition being evaluated, one of the two Boolean outputs is true and the other is false after the tool runs. These Boolean outputs must be set as a precondition to the downstream tools for those to run if either of the preconditions is true.
Parameters
Label Explanation Data type
Input Features
The input feature layer that will be evaluated.
Feature Layer
Feature Type
Specifies the type of feature that will be evaluated.
  • Annotation—Input annotation features will be evaluated.
  • Dimension—Input dimension features will be evaluated.
  • Edge—Input edge features will be evaluated.
  • Junction—Input junction features will be evaluated.
  • Line—Input line features will be evaluated.
  • Point—Input point features will be evaluated.
  • Polygon—Input polygon features will be evaluated.
  • Multipatch—Input multipatch features will be evaluated.
String
Derived output
True
If the specified criteria evaluates to True, this parameter will be set to True.
Boolean
False
If the specified criteria evaluates to False, this parameter will be set to True.
Boolean
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
