Iterate Field Values (Model Tools)
Summary
Iterates each value in a field.
Learn how Iterate Field Values works in ModelBuilder
Usage
  • This tool is only available from ModelBuilder for use in models. The tool is not available from the Geoprocessing pane or from Python.
  • The output of the tool is a variable named Value that contains the value of the field. This variable can be used in inline variable substitution (%Value%).
  • The Data Type parameter specifies the data type of the output variable. The default data type is string; however, depending on how the output will be used in the model, other data types can be specified. For example, if your field contains the path to a feature class, you can set the Data Type parameter to Feature Class and use the output variable as input to a tool that accepts a feature class.
  • If an iterator is added to a model, all tools in the model iterate for each value in the iterator. If you do not want to run each tool in the model for each iterated value, create a submodel, model within a model, or nested model that contains only the iterator and add it as a model tool to the main model.
Parameters
Label Explanation Data type
Input Table
The input table to be iterated.
Table View; Raster Layer
Field
The input field for iteration.
Field
Data Type
(Optional)
Specifies the data type of the output value. The default data type is string; however, depending on how the output will be used in the model, other data types can be specified. For example, if your field contains the path to a feature class, you can set this parameter to Feature Class and use the output variable as input to a tool that accepts a feature class.
  • 3D Object Feature Layer—3D Object Feature Layer
  • 3D Tiles Layer—3D Tiles Layer
  • Address Locator—Address Locator
  • Analysis Cell Size—Analysis Cell Size
  • Annotation Layer—Annotation Layer
  • Any Value—Any Value
  • ArcMap Document—ArcMap Document
  • Areal Unit—Areal Unit
  • BIM File Workspace—BIM File Workspace
  • Boolean—Boolean
  • Building Discipline Layer—Building Discipline Layer
  • Building Scene Discipline Layer—Building Scene Discipline Layer
  • Building Layer—Building Layer
  • Building Scene Layer—Building Scene Layer
  • CAD Drawing Dataset—CAD Drawing Dataset
  • Calculator Expression—Calculator Expression
  • Catalog Layer—Catalog Layer
  • Catalog Root—Catalog Root
  • Cell Size—Cell Size
  • Cell Size XY—Cell Size XY
  • Composite Layer—Composite Layer
  • Compression—Compression
  • Coordinate System—Coordinate System
  • Coordinate Systems Folder—Coordinate Systems Folder
  • Coverage—Coverage
  • Coverage Feature Class—Coverage Feature Class
  • Data Element—Data Element
  • Data File—Data File
  • Database Connections—Database Connections
  • Dataset—Dataset
  • Date—Date
  • dBASE Table—dBASE Table
  • Decimate—Decimate
  • Diagram Layer—Diagram Layer
  • Dimension Layer—Dimension Layer
  • Disk Connection—Disk Connection
  • Double—Double
  • Elevation Surface Layer—Elevation Surface Layer
  • Encrypted String—Encrypted String
  • Envelope—Envelope
  • Evaluation Scale—Evaluation Scale
  • Extent—Extent
  • Extract Values—Extract Values
  • Feature Class—Feature Class
  • Feature Dataset—Feature Dataset
  • Feature Layer—Feature Layer
  • Feature Set—Feature Set
  • Field—Field
  • Field Info—Field Info
  • Field Mappings—Field Mappings
  • File—File
  • Folder—Folder
  • Formulated Raster—Formulated Raster
  • Fuzzy Function—Fuzzy Function
  • GeoDataServer—GeoDataServer
  • Geodataset—Geodataset
  • Geometric Network—Geometric Network
  • Geostatistical Layer—Geostatistical Layer
  • Geostatistical Search Neighborhood—Geostatistical Search Neighborhood
  • Geostatistical Value Table—Geostatistical Value Table
  • GlobeServer—GlobeServer
  • GPServer—GPServer
  • Graph—Graph
  • Graph Data Table—Graph Data Table
  • Graphics Layer—Graphics Layer
  • Group Layer—Group Layer
  • Horizontal Factor—Horizontal Factor
  • Image Service—Image Service
  • Index—Index
  • INFO Expression—INFO Expression
  • INFO Item—INFO Item
  • INFO Table—INFO Table
  • Internet Tiled Layer—Internet Tiled Layer
  • KML Layer—KML Layer
  • Knowledge Graph Layer—Knowledge Graph Layer
  • LAS Dataset—LAS Dataset
  • LAS Dataset Layer—LAS Dataset Layer
  • Layer—Layer
  • Layer File—Layer File
  • Layout—Layout
  • Line—Line
  • Linear Unit—Linear Unit
  • Long—Long
  • M Domain—M Domain
  • Map—Map
  • Map Server—Map Server
  • Map Server Layer—Map Server Layer
  • Mosaic Dataset—Mosaic Dataset
  • Mosaic Layer—Mosaic Layer
  • Neighborhood—Neighborhood
  • Network Analyst Class FieldMap—Network Analyst Class FieldMap
  • Network Analyst Hierarchy Settings—Network Analyst Hierarchy Settings
  • Network Analyst Layer—Network Analyst Layer
  • Network Data Source—Network Data Source
  • Network Dataset—Network Dataset
  • Network Dataset Layer—Network Dataset Layer
  • Network Travel Mode—Network Travel Mode
  • Oriented Imagery Layer—Oriented Imagery Layer
  • Pairwise Weights Table—Pairwise Weights Table
  • Parcel Fabric—Parcel Fabric
  • Parcel Fabric for ArcMap—Parcel Fabric for ArcMap
  • Parcel Fabric Layer for ArcMap—Parcel Fabric Layer for ArcMap
  • Parcel Layer—Parcel Layer
  • Point—Point
  • Polygon—Polygon
  • Projection File—Projection File
  • Pyramid—Pyramid
  • Radius—Radius
  • Random Number Generator—Random Number Generator
  • Raster Band—Raster Band
  • Raster Calculator Expression—Raster Calculator Expression
  • Raster Catalog—Raster Catalog
  • Raster Catalog Layer—Raster Catalog Layer
  • Raster Data Layer—Raster Data Layer
  • Raster Dataset—Raster Dataset
  • Raster Layer—Raster Layer
  • Raster Statistics—Raster Statistics
  • Raster Type—Raster Type
  • Record Set—Record Set
  • Relationship Class—Relationship Class
  • Remap—Remap
  • Report—Report
  • Route Measure Event Properties—Route Measure Event Properties
  • Scene Layer—Scene Layer
  • Semivariogram—Semivariogram
  • ServerConnection—ServerConnection
  • Shapefile—Shapefile
  • Spatial Reference—Spatial Reference
  • SQL Expression—SQL Expression
  • String—String
  • String Hidden—String Hidden
  • Table—Table
  • Table View—Table View
  • Terrain Layer—Terrain Layer
  • Text File—Text File
  • Tile Size—Tile Size
  • Time Configuration—Time Configuration
  • Time Unit—Time Unit
  • TIN—TIN
  • TIN Layer—TIN Layer
  • Tool—Tool
  • Toolbox—Toolbox
  • Topo Features—Topo Features
  • Topology—Topology
  • Topology Layer—Topology Layer
  • Trace Network—Trace Network
  • Trace Network Layer—Trace Network Layer
  • Trajectory Layer—Trajectory Layer
  • Transformation Function—Transformation Function
  • Utility Network—Utility Network
  • Utility Network Layer—Utility Network Layer
  • Variant—Variant
  • Vector Tile Layer—Vector Tile Layer
  • Vertical Factor—Vertical Factor
  • Voxel Layer—Voxel Layer
  • VPF Coverage—VPF Coverage
  • VPF Table—VPF Table
  • WCS Coverage—WCS Coverage
  • Weighted Overlay Table—Weighted Overlay Table
  • Weighted Sum—Weighted Sum
  • WMS Map—WMS Map
  • WMTS Layer—WMTS Layer
  • Workspace—Workspace
  • XY Domain—XY Domain
  • Z Domain—Z Domain
String
Unique Values
(Optional)
Specifies whether iteration values will be based on unique values.
  • Checked—The iteration values will be based on the unique value of the specified field.
  • Unchecked—The iteration will run for each record in the input table.
Boolean
Skip Null Values
(Optional)
Specifies whether null values in the field will be skipped.
  • Checked—Null values in the field will be skipped during selection.
  • Unchecked—Null values in the field will not be skipped during selection.
Boolean
Null Value
(Optional)
The value that will be used to replace null values in the field, such as -9999, Null, or -1. The default for string fields is "" and 0 for numeric fields.
String
Derived output
Value
The field value returned by each iteration.
Any Value
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
