Iterate Workspaces (Model Tools)
Summary
Iterates over workspaces in a folder.
Learn how Iterate Workspaces works in ModelBuilder
Usage
  • This tool is only available from ModelBuilder for use in models. The tool is not available from the Geoprocessing pane or from Python.
  • The tool has two outputs: Workspace and Name which could be used as inline variable %Name% in other tools.
Parameters
Label Explanation Data type
Folder
The folder which stores the workspace to iterate.
Folder
Wildcard
(Optional)
A combination of * and characters that help to limit the results. The asterisk is the same as specifying ALL. If no wildcard is specified, all inputs will be returned. You can use this parameter to restrict iteration over input names starting with a certain character or word (for example, A* or Ari* or Land* and so on).
String
Workspace Type
(Optional)
Specifies the workspace type to find.
  • File geodatabase—Only file geodatabases will be the output.
  • Folder—Only folders will be the output.
  • Enterprise geodatabase—Only enterprise geodatabases will be the output.
  • BIM—Only BIM workspaces will be the output.
String
Recursive
(Optional)
Specifies if subfolders in the main folder will be iterated through recursively.
  • Checked—Will iterate through all subfolders.
  • Unchecked—Will not iterate through all subfolders. This is the default.
Boolean
Derived output
Workspace
The full path to the workspace.
Workspace
Name
The name of the workspace.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
