If Coordinate System Is (Model Tools)
Summary
Evaluates the input data for the specified coordinate system.
Usage
This tool is only available from ModelBuilder for use in models. The tool is not available from the Geoprocessing pane or from Python.
The tool has two Boolean outputs, True and False. Based on the condition being evaluated, one of the two Boolean outputs is true and the other is false after the tool runs. These Boolean outputs must be set as a precondition to the downstream tools for those to run if either of the preconditions is true.
Parameters
| Label | Explanation | Data type |
Input Data Element |
The input data element to be evaluated. |
Data Element; Layer; Table View; Graph; Utility Network |
Coordinate System |
The coordinate system that will be evaluated. |
Spatial Reference; String |
Derived output
True |
If the specified criteria evaluates to True, this parameter will be set to True. |
Boolean |
False |
If the specified criteria evaluates to False, this parameter will be set to True. |
Boolean |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
