If Field Exists (Model Tools)
Summary
Evaluates if the input data has the specified fields.
Learn how If Field Exists works in ModelBuilder
Usage
  • This tool is only available from ModelBuilder for use in models. The tool is not available from the Geoprocessing pane or from Python.
  • The tool has two Boolean outputs, True and False. Based on the condition being evaluated, one of the two Boolean outputs is true and the other is false after the tool runs. These Boolean outputs must be set as a precondition to the downstream tools for those to run if either of the preconditions is true.
Parameters
Label Explanation Data type
Input Table
Input table that will be evaluated for the existence of the specified fields.
Table View; Raster Layer; Mosaic Layer
Field Test
(Optional)
The criteria to test the specified list of fields against.
  • Must have all fields—All fields must exists.
  • Must have at least one field—Must have at least one of the specified fields.
  • Must not have all fields—Must not have any of the specified fields.
  • Must not have at least one field—Must not have at least one of the specified fields.
String
Fields
Field names to check for in the input table.
String
Derived output
True
If the specified criteria evaluates to True, this parameter will be set to True.
Boolean
False
If the specified criteria evaluates to False, this parameter will be set to True.
Boolean
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
