If Row Count Is (Model Tools)
Summary
Evaluates the row count of the input data and checks whether it matches a specified value.
Learn how If Row Count Is works in ModelBuilder
Usage
  • This tool is only available from ModelBuilder for use in models. The tool is not available from the Geoprocessing pane or from Python.
  • The tool has two Boolean outputs, True and False. Based on the condition being evaluated, one of the two Boolean outputs is true and the other is false after the tool runs. These Boolean outputs must be set as a precondition to the downstream tools for those to run if either of the preconditions is true.
Parameters
Label Explanation Data type
Layer Name or Table View
The input layer or table view to evaluate.
Table View; Raster Layer; Mosaic Layer
Count Condition
(Optional)
Specifies the condition to be used to test the field values of the records matching the SQL expression.
  • Is Equal to—Checks if the row count is equal to the Count value.
  • Is Between—Checks if the row count is between the Minimum Count value and Maximum Count value.
  • Is Less Than—Checks if the row count is less than the Count value.
  • Is Greater Than—Checks if the row count is greater than the Count value.
  • Is Not Equal to—Checks if the row count is not equal to the Count value.
String
Count
(Optional)
The integer count value.
Long
Minimum Count
(Optional)
The minimum integer count value.
Long
Maximum Count
(Optional)
The maximum integer count value.
Long
Derived output
True
If the specified criteria evaluates to True, this parameter will be set to True.
Boolean
False
If the specified criteria evaluates to False, this parameter will be set to True.
Boolean
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
