Make Closest Facility Layer (Network Analyst Tools)
Summary
Makes a closest facility network analysis layer and sets its analysis properties. A closest facility analysis layer is useful in determining the closest facility or facilities to an incident based on a specified network cost.
Legacy:
This is a deprecated tool. This functionality has been replaced by the Make Closest Facility Analysis Layer tool.
Usage
  • After creating the analysis layer with this tool, you can add network analysis objects to it using the Add Locations tool, solve the analysis using the Solve tool, and save the results on disk using the Save To Layer File tool.
  • When using this tool in geoprocessing models, if the model is run as a tool, the output network analysis layer must be made a model parameter; otherwise, the output layer is not added to the contents of the map.
Parameters
Label Explanation Data type
Input Analysis Network
The network dataset on which the closest facility analysis will be performed.
Network Dataset Layer
Output Layer Name
Name of the closest facility network analysis layer to create.
String
Impedance Attribute
The cost attribute that will be used as impedance in the analysis.
String
Travel From or To Facility
(Optional)
Specifies the direction of travel between facilities and incidents.
Using this option can find different facilities on a network with one-way restrictions and different impedances based on direction of travel. For instance, a facility may be a 10-minute drive from the incident while traveling from the incident to the facility, but while traveling from the facility to the incident, it may be a 15-minute journey because of different travel time in that direction.
  • Facilities to Incidents—Direction of travel is from facilities to incidents. Fire departments commonly use the this setting, since they are concerned with the time it takes to travel from the fire station (facility) to the location of the emergency (incident).
  • Incidents to Facilities—Direction of travel is from incidents to facilities. Retail stores commonly use this setting, since they are concerned with the time it takes the shoppers (incidents) to reach the store (facility).
String
Default Cutoff
(Optional)
Default impedance value at which to stop searching for facilities for a given incident. This default can be overridden by specifying the cutoff value on incidents when the direction of travel is from incidents to facilities or by specifying the cutoff value on facilities when the direction of travel is from facilities to incidents.
Double
Number of Facilities to Find
(Optional)
Default number of closest facilities to find per incident. The default can be overridden by specifying a value for the TargetFacilityCount property on the incidents.
Long
Accumulators
(Optional)
A list of cost attributes to be accumulated during analysis. These accumulation attributes are for reference only; the solver only uses the cost attribute specified by the Impedance Attribute parameter to calculate the route.
For each cost attribute that is accumulated, a Total_ [Impedance] property is added to the routes that are output by the solver.
String
U-Turn Policy
(Optional)
Specifies the U-turn policy that will be used at junctions. Allowing U-turns implies that the solver can turn around at a junction and double back on the same street. Given that junctions represent street intersections and dead ends, different vehicles may be able to turn around at some junctions but not at others—it depends on whether the junction represents an intersection or a dead end. To accommodate this, the U-turn policy parameter is implicitly specified by the number of edges that connect to the junction, which is known as junction valency. The acceptable values for this parameter are listed below; each is followed by a description of its meaning in terms of junction valency.
If you need a more precisely defined U-turn policy, consider adding a global turn delay evaluator to a network cost attribute or adjusting its settings if one exists, and pay particular attention to the configuration of reverse turns. You can also set the CurbApproach property of your network locations.
  • Allowed—U-turns are permitted at junctions with any number of connected edges. This is the default value.
  • Not allowed—U-turns are prohibited at all junctions, regardless of junction valency. However, U-turns are still permitted at network locations even when this option is specified, but you can set the individual network location's CurbApproach property to prohibit U-turns there as well.
  • Allowed at dead ends only—U-turns are prohibited at all junctions, except those that have only one adjacent edge (a dead end).
  • Allowed at dead ends and intersections only—U-turns are prohibited at junctions where exactly two adjacent edges meet but are permitted at intersections (junctions with three or more adjacent edges) and dead ends (junctions with exactly one adjacent edge). Often, networks have extraneous junctions in the middle of road segments. This option prevents vehicles from making U-turns at these locations.
String
Restrictions
(Optional)
A list of restriction attributes that will be applied during the analysis.
String
Use Hierarchy in Analysis
(Optional)
The parameter is not used if no hierarchy attribute is defined on the network dataset used to perform the analysis.
  • Checked—The hierarchy attribute will be used for the analysis. Using a hierarchy results in the solver preferring higher-order edges to lower-order edges. Hierarchical solves are faster, and they can be used to simulate the preference of a driver who chooses to travel on freeways rather than local roads when possible—even if that means a longer trip. This option is valid only if the input network dataset has a hierarchy attribute.
  • Unchecked—The hierarchy attribute will not be used for the analysis, and the result will be an exact route for the network dataset.
Boolean
Hierarchy Rank Settings
(Optional)
Legacy:
Prior to version 10, this parameter allowed you to change the hierarchy ranges for the analysis from the default hierarchy ranges established in the network dataset. At version 10, this parameter is no longer supported. To change the hierarchy ranges for the analysis, update the default hierarchy ranges in the network dataset.
Network Analyst Hierarchy Settings
Output Path Shape
(Optional)
Specifies the shape type that will be used for the route features that are output by the analysis.
Regardless of the output shape type specified, the best route is always determined by the network impedance, not Euclidean distance. This means that only the route shapes are different, not the underlying traversal of the network.
  • True lines with measures—The output routes will have the exact shape of the underlying network sources. The output includes route measurements for linear referencing. The measurements increase from the first stop and record the cumulative impedance to reach a given position.
  • True lines without measures—The output routes will have the exact shape of the underlying network sources.
  • Straight lines—The output route shape will be a single straight line between each paired incident and facility.
  • No lines—No shape will be generated for the output routes.
String
Time of Day
(Optional)
Specifies the time and date at which the routes should begin or end. The interpretation of this value depends on whether Time of Day Usage is set to be the start time or the end time of the route.
If you have chosen a traffic-based impedance attribute, the solution will be generated given dynamic traffic conditions at the time of day specified here. A date and time can be specified as 5/14/2012 10:30 AM.
Instead of using a particular date, a day of the week can be specified using the following dates.
  • Today—12/30/1899
  • Sunday—12/31/1899
  • Monday—1/1/1900
  • Tuesday—1/2/1900
  • Wednesday—1/3/1900
  • Thursday—1/4/1900
  • Friday—1/5/1900
  • Saturday—1/6/1900
For example, to specify that travel should begin at 5:00 PM on Tuesday, specify the parameter value as 1/2/1900 5:00 PM.
Date
Time of Day Usage
(Optional)
Indicates whether the value of the Time of Day parameter represents the arrival or departure time for the route or routes.
  • Start time—Time of Day is interpreted as the departure time from the facility or incident.When this setting is chosen, Time of Day indicates the solver should find the best route given a departure time.
  • End time—Time of Day is interpreted as the arrival time at the facility or incident. This option is useful if you want to know what time to depart from a location so that you arrive at the destination at the time specified in Time of Day.
  • Not used—When Time of Day doesn't have a value, this setting is the only choice. When Time of Day has a value, this setting isn't available.
String
Derived output
Network Analyst Layer
The newly created network analysis layer.
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
