Apply Partial Overlapping Edges Layout (Network Diagram Tools)
Summary
Spaces out collinear edges or collinear portions of edges (edge segments) inside a given buffer zone.
Learn more about the Partial Overlapping Edges layout algorithm
Caution:
If you have an open edit session, you must save your edits prior to running this tool. This ensures that the diagram reflects the latest changes made to the network topology in the database. If you fail to save your edits, the edits will not be reflected in the diagram.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Each layout algorithm includes default parameter values. The default parameter values will be used unless otherwise specified. If the input network diagram is based on a template for which this layout has been configured with a different parameter value, that value will be used instead.
Usage
  • This tool is not supported when working with a database connection to a utility network or trace network in an enterprise geodatabase. You must use either the related published utility network or trace network service, or a utility network or trace network in a file or mobile geodatabase.
  • The input network diagram layer must be from either a utility network or a trace network in a file or mobile geodatabase. or a network diagram service.
  • This layout algorithm detects sets of collinear edges or collinear portions of edges (edge segments) that can be considered inside a buffer zone of a given size.
  • The edges or segments must be relatively close to each other—more or less parallel, overlap, or nearly overlap—and similar in length. Segment buffer zones are then repositioned equally on the left and right sides, a proportional distance from the middle of the zone.
  • The distance between each segment is equal to a given offset. If vertices exist along diagram edges, the global orientation of the segments is preserved as much as possible. This is done so that, for example, a segment lying on the left side of another segment still ends up on the left side.
  • This layout algorithm is complex and may exceed the server time-out when applied to large diagrams. If you must apply the Partial Overlapping Edges Layout algorithm to the entire diagram content, consider running it in asynchronous mode on the server.
Parameters
Label Explanation Data type
Input Network Diagram Layer
The network diagram to which the layout will be applied.
Diagram Layer
Buffer Width
The width of the buffer zone in which to search for collinear edge segments.
Linear Unit
Offset
The distance that will separate the detected edge segments.
Linear Unit
Optimize edges
(Optional)
Specifies how segments will be placed along edges:
  • Checked—The placement of segments will be optimized in each set of collinear segments. This is done by focusing on their connections instead of their positions. Segments that cross each other can be repositioned so they do not cross.
  • Unchecked—The initial position of each segment will be maintained in the collinear segment set and crossings will be preserved. This is the default.
Boolean
Run in asynchronous mode on the server
(Optional)
Specifies whether the layout algorithm will run asynchronously or synchronously on the server.
  • Checked—The layout algorithm will run asynchronously on the server. This option dedicates server resources to run the layout algorithm with a longer time-out. Running asynchronously is recommended for layouts that are time consuming and may exceed the server time-out (for example, Partial Overlapping Edges) and applying to large diagrams (more than 25,000 features).
  • Unchecked—The layout algorithm will run synchronously on the server. It can fail without completion if it exceeds the service default time-out value of 600 seconds. This is the default.
Boolean
Derived output
Output Network Diagram
The updated network diagram layer.
Diagram Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
