Add Partial Overlapping Edges Layout (Network Diagram Tools)
Summary
Adds the Partial Overlapping Edges Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Partial Overlapping Edges Layout algorithm parameters for any diagram based on that template.
This layout algorithm detects sets of collinear edges or collinear portions of edges (edge segments) that can be considered inside a buffer zone of a given size.
Learn more about the Partial Overlapping Edges layout algorithm
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • To preset the layout algorithm parameters for a diagram based on the diagram template, uncheck the Active parameter (is_active = "INACTIVE" in Python).
  • Run the tool with Active checked (is_active = "ACTIVE" in Python) if you want the layout algorithm to be added to the list of layouts that will be automatically chained at the end of diagram generation based on the input diagram template.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template that will be modified.
Utility Network; Trace Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the layout algorithm will automatically run when generating diagrams based on the specified template.
  • Checked—The added layout algorithm will automatically run during the generation of any diagram based on the input template. This is the default. The parameter values specified for the layout algorithm are used to run the layout during diagram generation. They are also loaded by default when the algorithm is to be run on any diagram based on the input template.
  • Unchecked—All the parameter values currently specified for the added layout algorithm will be loaded by default when the algorithm is to be run on any diagram based on the input template.
Boolean
Buffer Width
The width of the buffer zone in which to search for collinear edge segments.
Linear Unit
Offset
The distance that will separate the detected edge segments.
Linear Unit
Optimize edges
(Optional)
Specifies how segments will be placed along edges:
  • Checked—The placement of segments will be optimized in each set of collinear segments. This is done by focusing on their connections instead of their positions. Segments that cross each other can be repositioned so they do not cross.
  • Unchecked—The initial position of each segment will be maintained in the collinear segment set and crossings will be preserved. This is the default.
Boolean
Derived output
Output Network
The updated utility network or trace network.
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
