An overview of the Configuration toolset
The Configuration toolset contains tools to create, configure, and manage diagram templates.
The tools are used to do the following:
Manage the stages of a network diagram template—Creation, deletion, properties, and diagram layer definition.
Add a specific layout to a diagram template—Use the Add <XXX> Layout tools to add a layout algorithm to the list of automatic algorithms of a template. Every new layout that is added to a template is appended to the end of the list of automatic layouts.
Add a specific rule to a diagram template—The Add <XXX> Rule and Add <XXX> Rule By Attribute tools allow you to configure rules that are added to a template rule sequence.
Tool |
Description |
Adds the Angle Directed Layout algorithm to the list of layouts to be automatically chained at the end of the generation of diagrams based on a given template. This tool also presets the Angle Directed Layout algorithm parameters for any diagram based on that template. |
Adds a diagram rule to the rule sequence specified on a diagram template to automatically collapse all contents related to containers during diagram buildings. The containers with contents to be collapsed are identified using an SQL query based on their attributes. |
Adds a diagram rule to automatically collapse container contents during the building of diagrams based on an existing template. The collapse depends on whether the containers are tagged with specific network categories. |
Adds a diagram rule to the rule sequence specified on a diagram template to automatically collapse container contents during diagram buildings. This rule collapses all of the container contents in the diagrams. |
Adds the Compression layout algorithm to the layout list of the input diagram template so it automatically runs at the end of diagram buildings. This tool also presets the Compression layout algorithm parameters for any diagram based on that template. |
Adds a diagram rule to automatically represent connectivity associations during the building of diagrams based on an existing template. This rule processes connectivity associations in which both the from and to junctions are currently represented in the diagrams. |
Adds a diagram rule to the rule sequence specified on a diagram template to assign a particular capability on diagram features currently represented in the diagram during the diagram building process. This capability is used by other rules that run later in the rule sequence. The diagram features that will be processed are queried from a network source class or object table by attributes. |
Adds a diagram rule to assign a particular capability to diagram features according to network categories. This assignment occurs during the building of diagrams based on an existing template. This capability is used by other rules that are run later in the rule sequence. The diagram features that will be processed depend on whether they are tagged with specific network categories. |
Adds the diagram feature selection to which the next active layout configured on the diagram template will apply. |
Adds a new diagram template to a network. A network diagram rule and layout definitions file ( |
Adds a diagram rule to the rule sequence specified on a diagram template to automatically expand container contents during diagram buildings. The containers to expand are filtered by attributes from a given container source class or object table. |
Adds a diagram rule to automatically expand container contents during the building of diagrams based on an existing template. This expansion depends on whether the containers are tagged with specific network categories. |
Adds a diagram rule to the rule sequence specified on a diagram template to automatically expand container contents during diagram buildings. This rule expands all of the container contents in the diagrams. |
Adds the Force Directed Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Force Directed Layout algorithm parameters for any diagram based on that template. |
Adds the Grid Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Grid Layout algorithm parameters for any diagram based on that template. |
Adds the Linear Dispatch Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Linear Dispatch Layout algorithm parameters for any diagram based on that template. |
Adds the Main Ring Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Main Ring Layout algorithm parameters for any diagram based on that template. |
Adds the Mainline Tree Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Mainline Tree Layout algorithm parameters for any diagram based on that template. |
Adds the Partial Overlapping Edges Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Partial Overlapping Edges Layout algorithm parameters for any diagram based on that template. |
Adds the Radial Tree Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Radial Tree Layout algorithm parameters for any diagram based on that template. |
Adds a diagram rule to automatically reduce diagram edges during diagram building based on an existing template. This rule can be set up to reduce diagram edges by attributes. |
Adds a diagram rule to the rule sequence specified on a diagram template to automatically reduce diagram junctions during diagram buildings. The junctions that will be reduced are queried from a given network junction source class or object table by attributes according to the number of other junctions to which they are connected. |
Adds a diagram rule to automatically reduce junctions during the building of diagrams based on an existing template. This reduction depends on whether the junctions are tagged with specific network categories. |
Adds a diagram rule to the rule sequence specified on a diagram template to automatically reduce diagram junctions during the diagram building process. This tool reduces junctions based on several network junction source classes and object tables according to the number of other junctions to which they are connected. |
Adds the Relative Mainline Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Relative Mainline Layout algorithm parameters for any diagram based on that template. |
Adds a diagram rule to the rule sequence specified on a diagram template to automatically remove diagram features during diagram buildings. The features that will be removed are queried by attributes from a given network source class or object table. You can also constrain the removal of features based on connectivity. |
Adds a diagram rule to automatically remove diagram features during diagram building based on an existing template. This removal depends on whether the diagram features are tagged with specific network categories. You can also constrain the removal of features based on connectivity. |
Adds a diagram rule to the rule sequence specified on a diagram template to automatically remove diagram features during diagram buildings. This rule removes diagram features based on different network source classes and object tables. You can constrain the removal of features based on connectivity. |
Adds the Reshape Diagram Edges Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Reshape Diagram Edges Layout algorithm parameters for any diagram based on that template. |
Adds a diagram rule to automatically flag diagram junctions as root junctions during diagram building based on an existing template. This rule specifies root junctions based on a particular junction source class or object table and filters using their attributes. |
Adds a diagram rule to a diagram template to set diagram features currently represented in the diagram as starting points for tracing rules. The diagram features are queried from a given network source class or object table and can be filtered by their attributes. |
Adds the Smart Tree Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Smart Tree Layout algorithm parameters for any diagram based on that template. |
Adds the Spatial Dispatch Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Spatial Dispatch Layout algorithm parameters for any diagram based on that template. |
Adds a diagram rule that automatically appends new network features to the diagrams based on their location relative to the network features currently represented in the diagram. |
Adds a diagram rule to specify the beginning of a rule sequence during diagram building based on an existing template. |
Adds a diagram rule to specify the end of a rule sequence during diagram building based on an existing template. |
Adds a diagram rule to automatically represent structural attachments during diagram building based on an existing template. This rule applies to structural attachment associations in which both the attached network element and the structure element are currently represented in the diagrams. |
Adds a diagram rule to the rule sequence specified on a diagram template to automatically run a trace on a utility network or trace network during diagram building. The resulting traced network features and network objects are used to build the diagram content. |
Alters the properties of a diagram template. |
Creates a diagram layer definition for the input diagram template using the settings of the network feature layers in the active map. |
Creates a geoprocessing model with network diagram configuration tools that will set up the rules and layouts on the input diagram template. |
Deletes one or more stored network diagrams, which are optionally filtered by their diagram template names, related to a given network. |
Exports the diagram layer definition currently set up for the input diagram layer into a network diagram layer definition file ( |
Exports the network diagram rule and layout definitions and the network diagram layer definition to |
Returns the names of all diagram templates related to a network. |
Imports a network diagram rule and layout definitions file ( |
