Add Reshape Diagram Edges Layout (Network Diagram Tools)
Summary
Adds the Reshape Diagram Edges Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Reshape Diagram Edges Layout algorithm parameters for any diagram based on that template.
This layout algorithm is used to process simple operations on vertices along edges in network diagrams. It allows you to do the following:
  • Remove all vertices along diagram edges.
  • Reduce some vertices along diagram edges.
  • Square diagram edges with the addition of vertices on edges.
  • Separate diagram edges that overlap.
  • Detect diagram edges that cross each other at right angles and reshape their geometries to display a circular arc at the crossing locations.
Learn more about the Reshape Diagram Edges layout algorithm
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • To preset the layout algorithm parameters for a diagram based on the diagram template, uncheck the Active parameter (is_active = "INACTIVE" in Python).
  • Run the tool with Active checked (is_active = "ACTIVE" in Python) if you want the layout algorithm to be added to the list of layouts that will be automatically chained at the end of diagram generation based on the input diagram template.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template that will be modified.
Utility Network; Trace Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the layout algorithm will automatically run when generating diagrams based on the specified template.
  • Checked—The added layout algorithm will automatically run during the generation of any diagram based on the input template. This is the default. The parameter values specified for the layout algorithm are used to run the layout during diagram generation. They are also loaded by default when the algorithm is to be run on any diagram based on the input template.
  • Unchecked—All the parameter values currently specified for the added layout algorithm will be loaded by default when the algorithm is to be run on any diagram based on the input template.
Boolean
Preserve container layout
(Optional)
Specifies how the layout algorithm will process containers.
  • Checked—The layout algorithm will apply to the top graph of the diagram so container layouts are preserved.
  • Unchecked—The layout algorithm will apply to both content and noncontent features in the diagram. This is the default.
Boolean
Reshape Operation
Specifies how edges will be reshaped.
  • Remove vertices—Vertices along edges in the diagram will be removed.
  • Square edges—Vertices will be placed along diagram edges, and the edges will be displayed with right angles. This is the default.
  • Separate overlapping edges—Edges that connect the same origin and extremity junctions will be separated when they are overlapping.
  • Reduce vertices by angle—Some or all vertices displayed along diagram edges will be reduced according to the angle that separates the segments incident to those vertices.
  • Mark crossing edges—The horizontal and vertical diagram edges that cross each other at a right angle in the diagram will be marked, and the geometry of one of the crossing edges will be reshaped to display a circular arc at this location.
String
Preserve path
(Optional)
Specifies whether vertices along the edges that will be squared will be preserved.
This parameter is only enabled when the Reshape Operation parameter value is set to Square edges.
  • Checked—The direction of any edge will be considered, and vertices along that edge will be preserved from the first vertex to the last. This is the default.
  • Unchecked—Vertices along the diagram edges will not be considered, and the vertices will be removed.
Boolean
Offset Between Edges
(Optional)
The spacing that will separate parallel segments of squared edges incident to the same junction. The default is 5 in the units of the diagram's coordinate system. This parameter is only enabled when the Reshape Operation is Square edges.
Linear Unit
Break Point Position
(Optional)
The maximum distance between each junction to the first or last break point along edges incident to that junction when those edges are squared. The default is 8.66 in the units of the diagram's coordinate system. This parameter is only enabled when the Reshape Operation parameter is set to Square edges.
Linear Unit
(Optional)
The absolute spacing that will separate two edges. The default is 0.5 in the units of the diagram's coordinate system. This parameter is only enabled when the Reshape Operation parameter is set to Separate overlapping edges.
Linear Unit
Angle Threshold
(Optional)
The angle formed by the incident segments over which the vertex related to these segments will be reduced. The wider the angle, the fewer number of vertices will be reduced. The default is 160 degrees. This parameter is enabled when the Reshape Operation parameter is set to Reduce vertices by angle.
Double
Circular Arc Radius
(Optional)
The radius of the circular arc that will be added to the crossing edge locations. The default is 5.
Linear Unit
Circular Arc Position
(Optional)
Specifies the segment on which a circular arc will be placed.
  • Left of vertical segment—A circular arc will be placed to the left of the vertical segment.
  • Right of vertical segment—A circular arc will be placed to the right of the vertical segment.
  • Above horizontal segment—A circular arc will be placed above the horizontal segment.
  • Below horizontal segment—A circular arc will be placed below the horizontal segment.
String
Derived output
Output Network
The updated utility network or trace network.
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
