Reshape Diagram Edges Layout (Network Diagram Tools)
Summary
Processes simple operations on vertices along edges.
Learn more about the Reshape Diagram Edges layout algorithm
Caution:
If you have an open edit session, you must save your edits prior to running this tool. This ensures that the diagram reflects the latest changes made to the network topology in the database. If you fail to save your edits, the edits will not be reflected in the diagram.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Each layout algorithm includes default parameter values. The default parameter values will be used unless otherwise specified. If the input network diagram is based on a template for which this layout has been configured with a different parameter value, that value will be used instead.
Usage
  • This tool is not supported when working with a database connection to a utility network or trace network in an enterprise geodatabase. You must use either the related published utility network or trace network service, or a utility network or trace network in a file or mobile geodatabase.
  • The input network diagram layer must be from either a utility network or a trace network in a file or mobile geodatabase. or a network diagram service.
  • This layout algorithm is used to process simple operations on vertices along edges in network diagrams. It allows you to do the following:
    • Remove all vertices along diagram edges.
    • Reduce some vertices along diagram edges.
    • Square diagram edges with the addition of vertices on edges.
    • Separate diagram edges that overlap.
    • Detect diagram edges that cross each other at right angles and reshape their geometries to display a circular arc at the crossing locations.
  • Consider applying the layout in asynchronous mode on the server when working on very large diagrams.
Parameters
Label Explanation Data type
Input Network Diagram Layer
The network diagram to which the layout will be applied.
Diagram Layer
Preserve container layout
(Optional)
Specifies how the algorithm will process containers.
  • Checked—The Reshape Diagram Edges layout algorithm will apply to the top graph of the diagram so container layouts are preserved.
  • Unchecked—The Reshape Diagram Edges layout algorithm will apply to both content and noncontent features in the diagram. This is the default.
Boolean
Reshape Operation
Specifies how edges will be reshaped.
  • Remove vertices—Vertices along edges in the diagram will be removed.
  • Square edges—Vertices will be placed along diagram edges, and the edges will be displayed with right angles. This is the default.
  • Separate overlapping edges—Edges that connect the same origin and extremity junctions will be separated when they are overlapping.
  • Reduce vertices by angle—Some or all vertices displayed along diagram edges will be reduced according to the angle that separates the segments incident to those vertices.
  • Mark crossing edges—The horizontal and vertical diagram edges that cross each other at a right angle in the diagram will be marked, and the geometry of one of the crossing edges will be reshaped to display a circular arc at this location.
String
Preserve path
(Optional)
Specifies whether vertices along the edges that will be squared will be preserved. This parameter is only enabled when the Reshape Operation parameter is set to Square edges.
  • Checked—The direction of any edge will be considered, and vertices along that edge will be preserved from the first vertex to the last. This is the default.
  • Unchecked—Vertices along the diagram edges will not be considered, and the vertices will be removed.
Boolean
Offset Between Edges
(Optional)
The spacing that will separate parallel segments of squared edges incident to the same junction. The default is 5 in the units of the diagram's coordinate system. This parameter is only enabled when the Reshape Operation parameter is set to Square edges.
Linear Unit
Break Point Position
(Optional)
The maximum distance between each junction to the first or last break point along edges incident to that junction when those edges are squared. The default is 8.66 in the units of the diagram's coordinate system. This parameter is only enabled when the Reshape Operation parameter is set to Square edges.
Linear Unit
(Optional)
The absolute spacing that will separate two edges. The default is 0.5 in the units of the diagram's coordinate system. This parameter is only enabled when the Reshape Operation parameter is set to Separate overlapping edges.
Linear Unit
Angle Threshold
(Optional)
The angle formed by the incident segments over which the vertex related to these segments will be reduced. The wider the angle, the fewer number of vertices will be reduced. The default is 160 degrees. This parameter is only enabled when the Reshape Operation parameter is set to Reduce vertices by angle.
Double
Circular Arc Radius
(Optional)
The radius of the circular arc that will be added to the crossing edge locations. The default is 5.
Linear Unit
Circular Arc Position
(Optional)
Specifies the segment on which a circular arc will be placed.
  • Left of vertical segment—A circular arc will be placed to the left of the vertical segment.
  • Right of vertical segment—A circular arc will be placed to the right of the vertical segment.
  • Above horizontal segment—A circular arc will be placed above the horizontal segment.
  • Below horizontal segment—A circular arc will be placed below the horizontal segment.
String
Run in asynchronous mode on the server
(Optional)
Specifies whether the layout algorithm will run asynchronously or synchronously on the server.
  • Checked—The layout algorithm will run asynchronously on the server. This option dedicates server resources to run the layout algorithm with a longer time-out. Running asynchronously is recommended for layouts that are time consuming and may exceed the server time-out (for example, Partial Overlapping Edges) and applying to large diagrams (more than 25,000 features).
  • Unchecked—The layout algorithm will run synchronously on the server. It can fail without completion if it exceeds the service default time-out value of 600 seconds. This is the default.
Boolean
Derived output
Output Network Diagram
The updated network diagram layer.
Diagram Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
