Add Collapse Container Rule (Network Diagram Tools)
Summary
Adds a diagram rule to the rule sequence specified on a diagram template to automatically collapse container contents during diagram buildings. This rule collapses all of the container contents in the diagrams.
Learn more about collapsing containers in network diagrams
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • The Collapse Container rule is used to simplify diagrams by collapsing all contents related to containers that may exist in diagrams.
    You can use this tool to configure the Collapse Container rule to collapse all container contents in the diagram that are based on specified container source classes and object tables. You can also use it to collapse all container contents in the diagram except those based on the specified container source classes or object tables.
    When it is configured by default—the Rule Process parameter set to Exclude source classes and the Container Type parameter set to Both junctions and edges and no source container classes or object tables are specified—all contents in the generated diagrams will be collapsed regardless of the network source container class or object table they are related to.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template that will be modified.
Utility Network; Trace Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the rule will be enabled when generating and updating diagrams based on the specified template.
  • Checked—The added rule will become enabled during the generation and update of any diagrams based on the input template. This is the default.
  • Unchecked—The added rule will not become enabled during the generation or update of any diagrams based on the input template.
Boolean
Container Type
Specifies the geometry type of the container source class or object table that will be processed.
  • Junctions only—Only junction container source classes and object tables (polygon container source classes, point container source classes, and container junction object tables) will be processed.
  • Edges only—Only edge container source classes and object tables (linear container source classes or container edge object tables) will be processed.
  • Both junctions and edges—All container source classes and object tables regardless of their type (both junction and edge types) will be processed. This is the default.
String
Rule Process
Specifies how the specified container source classes and object tables will be processed.
  • Exclude source classes—Containers that are based on the specified source classes and object tables will not be collapsed, while other containers will be collapsed. This is the default.
  • Include source classes—Containers that are based on the specified source classes and object tables will be collapsed.
String
Container Sources
(Optional)
The container source class (or classes) and object table (or tables) that will be excluded or included depending on the rule process.
When Rule Process is set to Exclude source classes, the rule can be configured without specifying a network source class or object table. In this case, it will collapse contents of any container source classes and object tables in the generated diagrams. When Rule Process is set to Include source classes, the container source class (or classes) or object table (or tables) to be collapsed must be specified.
When Rule Process is set to Exclude source classes, the contents related to any container features or container objects belonging to the specified classes or object tables will not be collapsed in the generated diagrams; however, contents related to container features and container objects that don't belong to those classes and object tables will be collapsed. Conversely, when Rule Process is set to Include source classes , the contents related to any container features and container objects belonging to the specified source classes and object tables will be collapsed in the generated diagrams; however, contents related to container features and container objects that don't belong to those source classes and object tables will not be collapsed.
Table; Feature Class
(Optional)
The description of the rule.
String
Aggregate reconnected edges
(Optional)
Specifies whether edges that are reconnected to the collapsed junctions will be aggregated.
  • Checked—Any edge connecting a content junction will be replaced by a reduction edge that is reconnected to the collapsed container junction. Multiple edges between two collapsed junctions will be systematically aggregated under the same reduction edge. This is the default.
  • Unchecked—Any edge connecting a content junction will be kept and reconnected to the collapsed container junction.
Boolean
Derived output
Output Network
The updated utility network or trace network.
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
