Add Collapse Container By Attribute Rule (Network Diagram Tools)
Summary
Adds a diagram rule to the rule sequence specified on a diagram template to automatically collapse all contents related to containers during diagram buildings. The containers with contents to be collapsed are identified using an SQL query based on their attributes.
Learn more about collapsing containers in network diagrams
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • The Collapse Container rule is used to simplify diagrams by collapsing all contents related to containers that may exist in diagrams.
    You can use this tool to configure the Collapse Container rule to run by attributes. This means that you can configure the collapse of diagram features of a particular container class or object table by filtering the container elements to collapse based on their attributes.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template that will be modified.
Utility Network; Trace Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the rule will be enabled when generating and updating diagrams based on the specified template.
  • Checked—The added rule will become enabled during the generation and update of any diagrams based on the input template. This is the default.
  • Unchecked—The added rule will not become enabled during the generation or update of any diagrams based on the input template.
Boolean
Container Source
The container source class or object table that references the containers with the contents to be collapsed.
Table; Feature Class
Expression
(Optional)
An SQL expression that will be used to select the subset of containers in this source class or object table with the contents to be collapsed in the generated diagrams.
SQL Expression
(Optional)
The description of the rule.
String
Aggregate reconnected edges
(Optional)
Specifies whether edges that are reconnected to the collapsed junctions will be aggregated.
  • Checked—Any edge connecting a content junction will be replaced by a reduction edge that is reconnected to the collapsed container junction. Multiple edges between two collapsed junctions will be systematically aggregated under the same reduction edge. This is the default.
  • Unchecked—Any edge connecting a content junction will be kept and reconnected to the collapsed container junction.
Boolean
Derived output
Output Network
The updated utility network or trace network.
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
