Add Diagram Template (Network Diagram Tools)
Summary
Adds a new diagram template to a network. A network diagram rule and layout definitions file (.ndbd) and a network diagram layer definition file (.ndld) can be imported.
Caution:
This tool is a configuration and administration tool.
Usage
This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
The Input Network parameter value must be from a database connection established as the database utility network owner or database trace network owner.
The connected ArcGIS Enterprise portal account must be the portal utility network owner or portal trace network owner.
This tool must be connected to the default version, which is expected to be public and not protected.
Adding a new diagram template to a specified input network will create a template with no particular settings.
When the tool runs with either no
.ndldfile or an empty.ndldfile in input, the tool process automatically initializes a default diagram layer definition on the newly created template.The tool adds a layer definition ID to the template. This ID helps the network owner to control how diagram layer definitions are shared between diagram templates and improve this sharing. For a published utility network or trace network service, this ID also improves the service start time.
Parameters
| Label | Explanation | Data type |
Input Network |
The utility network or trace network to which the template will be added. |
Utility Network; Trace Network |
Diagram Template Name |
The name of the output diagram template. |
String |
Rule and Layout Definitions File (Optional) |
The network diagram rule and layout definitions file ( |
File |
Diagram Layer Definition File (Optional) |
The diagram layer definition file ( When this parameter is not specified or loads an empty |
File |
Derived output
Output Network |
The updated utility network or trace network. |
Output Diagram Template |
The name of the diagram template. |
String |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
