Export Diagram Layer Definition (Network Diagram Tools)
Summary
Exports the diagram layer definition currently set up for the input diagram layer into a network diagram layer definition file (.ndld).
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • The tool creates an output network diagram layer definition file (.ndld). The definition file stores all layer and labelling properties of each layer under the input network diagram layer. The Import Diagram Template Definitions tool can be used to apply the template across other layers so that they display in the same way.
  • Since this tool works from an input network diagram layer in the active map, it can be used in ArcGIS Pro only.
Parameters
Label Explanation Data type
Input Network Diagram Layer
The network diagram layer from which the layer definition will be exported.
Diagram Layer
Output File
The network diagram layer definition file (.ndld) to be created.
File
Derived output
Output Network Diagram Layer
The output network diagram layer.
Diagram Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
