Introduction to diagram templates
When you generate a diagram, you choose a template on which your diagram will be based. The diagram template contains the definitions of the diagram rules, layouts, and layer. In other words, it contains the configuration properties that define the content (rule and layout definitions) and presentation (diagram layer definition) of network diagrams that will be generated.
The three diagram templates included in a utility network or trace network are as follows:
  • Basic—This is the default template used to generate diagrams. Use this template to generate basic diagrams from the network elements currently selected in the map. A diagram feature is created for each selected network element. Any content features or objects represented in the diagram receive a diagram feature to represent the container.
  • ExpandContainers—Use this template to generate diagrams with expanded containers represented by diagram polygon containers.
  • CollapseContainers—Use this template to generate diagrams with collapsed containers represented by collapsed diagram junctions and collapsed diagram edges. A single diagram line or point feature represents a container and its set of content.
These three diagram templates are generic; their definitions are not specific to any network domain, and they do not process particular network elements. These are provided to allow you to gain familiarity with network diagrams by generating simple diagrams, but have limited scope. Network Diagram's added value can be measured when adding diagram templates that allow the automatic tracing of the network, which is rerun at each diagram update, or producing diagrams that show a simplified network graph.
To produce network diagrams that will highlight your network specifics, simplify your daily work, and facilitate decision-making, you can create your own diagram templates and consider the diagram rules that need to be chained to build them. The rules in the diagram templates installed by default with a utility network or trace network are detailed in the next sections.
Installed diagram template definitions
The three out-of-the-box diagram templates can be re-created if needed. The sections below detail the rules that must be chained together to re-create each diagram template.
Basic diagram template definitions
To create a diagram template similar to the Basic template, the following geoprocessing tools must be chained together in the order shown:
ExpandContainers diagram template definitions
To re-create the ExpandContainers diagram template, the following geoprocessing tools must be set up and run in the order shown:
CollapseContainers diagram template definitions
To re-create the CollapseContainers diagram template, the following geoprocessing tools must be set up and run in the order shown:
Diagram templates available for a network
To review the existing diagram templates for a given network and view their main settings, you can run the following workflow:
  1. In the Catalog pane, depending on whether you are working with a geodatabase or a service, do one of the following:
    • Expand your database item and locate and right-click the utility network or trace network data element.
    • Click the Portal tab and locate and right-click the utility network feature layer.
  2. Click Properties.
  3. On the network properties dialog box that appears, click the Network Diagrams tab
The Diagram Templates table in this tab lists the names of existing diagram templates in the utility network and allows you to review their related properties.
Diagram template properties
For each template listed in the Network Diagrams tab, you have the following information:
  • Name—The diagram template name
  • Created Time—The template creation date
  • Last Modified Time—The last time the template was modified
  • Diagram Storage—Whether the template allows diagrams to be stored
  • Is System—Whether the template is set as a diagram template for subnetwork tiers
  • Extend Diagram—Whether the template enables diagrams to be extended
  • Keep Edge Vertices—Whether the template handles vertices on network edges.
  • Remove Linear Containers—Whether the template systematically removes all linear containers at the end of diagram building.
  • Persist Aggregations—Whether the template persists aggregations during diagram building.
  • Layer Definitions Sharing—Whether the template shares a same layer definition with other templates.
  • Associated Telecom Domain—The name of the telecom domain associated to the template.
  • Description—The template description
Most of these properties can be edited using the Alter Diagram Template tool.
Keep Edge Vertices, Remove Linear Containers, Persist Aggregations, Layer Definitions ID, and Associated Telecom Domain are not available in versions prior to ArcGIS Pro 3.7.
