Add Connectivity Associations Rule (Network Diagram Tools)
Summary
Adds a diagram rule to automatically represent connectivity associations during the building of diagrams based on an existing template. This rule processes connectivity associations in which both the from and to junctions are currently represented in the diagrams.
Learn more about adding connectivity associations to diagrams
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • Connectivity associations are not drawn by default in a network map. The Add Connectivity Associations rule allows you to generate diagrams in which connectivity associations are systematically drawn each time the related from and to junctions are present in the diagram at the time the rule runs. They display as straight diagram edges between the from and to diagram junctions they connect.
  • Consider the diagram template's rule sequence before adding an Add Connectivity Associations rule, because it is time consuming. The Add Connectivity Associations rule should only be set on templates when the completeness of the diagram graph regarding connectivity associations is not already guaranteed by other diagram rules. For example, if the template is already configured to run a Trace rule, there is no reason to specify an Add Connectivity Associations rule, since connectivity associations will be returned by the trace.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template that will be modified.
Utility Network; Trace Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the rule will be enabled when generating and updating diagrams based on the specified template.
  • Checked—The added rule will become enabled during the generation and update of any diagrams based on the input template. This is the default.
  • Unchecked—The added rule will not become enabled during the generation or update of any diagrams based on the input template.
Boolean
(Optional)
The description of the rule.
String
Derived output
Output Network
The updated utility network or trace network.
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
