Add Structural Attachments Rule (Network Diagram Tools)
Summary
Adds a diagram rule to automatically represent structural attachments during diagram building based on an existing template. This rule applies to structural attachment associations in which both the attached network element and the structure element are currently represented in the diagrams.
Learn more about adding structural attachments to diagrams
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network service. You must use either a utility network in a file or mobile geodatabase or a database connection to a utility network in an enterprise geodatabase. When working with an enterprise geodatabase the following are requirements:
    • The Input Network parameter value must be from a database connection established as the database utility network owner.
    • The connected ArcGIS Enterprise portal account must be the portal utility network owner.
    • This tool must be connected to the default version, which is public and not protected.
  • Structural attachment associations are not drawn by default in a network map. The Add Structural Attachments rule allows you to generate diagrams in which structural attachment associations are systematically drawn each time the attached network element and structure element are present in the diagram at the time the rule runs. They appear as straight diagram edges between the related attached and structure diagram features.
  • This rule is time consuming. Consider your existing template rule sequence before configuring it on diagram templates. Only use an Add Structural Attachment rule if it will impact the resulting diagrams. For example, if there are Remove Feature rules configured to remove all structures in the generated diagrams, there is no reason to add a Structural Attachments rule to the template.
Parameters
Label Explanation Data type
Input Network
The utility network containing the diagram template to modify.
Utility Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the rule will be enabled when generating and updating diagrams based on the specified template.
  • Checked—The added rule will become enabled during the generation and update of any diagrams based on the input template. This is the default.
  • Unchecked—The added rule will not become enabled during the generation or update of any diagrams based on the input template.
Boolean
(Optional)
The description of the rule.
String
Derived output
Output Network
The updated utility network.
Utility Network
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
