Add Structural Attachments rule reference
The Add Structural Attachments rule is used to add explicit edges to the diagram that represent structural attachment associations for both the attached network element and the structure element that are currently represented in the diagram.
Learn more about structural attachments in diagrams
Add Structural Attachments rule process
Structural attachment associations are not drawn by default in a network map. The Add Structural Attachments rule allows you to generate diagrams in which structural attachment associations are systematically drawn each time the attached network element and structure element are present in the diagram at the time the rule runs. They appear as straight diagram edges between the related attached and structure diagram features.
Caution:
Running the Add Structural Attachments rule is time-consuming.
Add Structural Attachments rule configuration
You can configure an Add Structural Attachments rule on a template with the Add Structural Attachments Rule tool.
