Add Expand Container Rule (Network Diagram Tools)
Summary
Adds a diagram rule to the rule sequence specified on a diagram template to automatically expand container contents during diagram buildings. This rule expands all of the container contents in the diagrams.
Learn more about expanding containers in network diagrams
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • The Expand Container rule is used to expand diagrams by adding content features or objects that adhere to the following:
    • They are contained in a container in the diagram input.
    • They share the same container as content in the diagram input.
    The Expand Container rule expands the containers by source class or object table, or by network categories. When the rule is configured to process on a container network source class or object table, you can filter out these containers by attributes.
    You can use this tool to configure the Expand Container rule to expand all containers in the diagram that are based on specified container source classes and object tables. You can also use it to expand all containers in the diagram except those based on the specified container source classes and object tables.
    When it is configured by default—the Rule Process parameter set to Exclude source classes and the Container Type parameter set to Both junctions and edges and no container source classes or object tables are specified—each container in the generated diagrams will be expanded regardless of the container source class or object table on which it is based.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template that will be modified.
Utility Network; Trace Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the rule will be enabled when generating and updating diagrams based on the specified template.
  • Checked—The added rule will become enabled during the generation and update of any diagrams based on the input template. This is the default.
  • Unchecked—The added rule will not become enabled during the generation or update of any diagrams based on the input template.
Boolean
Keep containers visible
Specifies whether the containers stay visible after they are expanded.
  • Checked—The containers will stay visible after they are expanded. This is the default.
  • Unchecked—The containers will be hidden after they are expanded.
Boolean
Container Type
Specifies the geometry type of the container source class or object table that will be processed.
  • Junctions only—Only junction container source classes or object tables (polygon container source classes, point container source classes, or container junction object tables) will be processed.
  • Edges only—Only edge container source classes or object tables (linear container source classes or container edge object tables) will be processed.
  • Both junctions and edges—All container source classes and object tables regardless of their type (both junction and edge types) will be processed. This is the default.
String
Rule Process
Specifies how the specified container source classes and object tables will be processed.
  • Exclude source classes—Containers that are based on the specified source classes and object tables will not be expanded, while other containers will be expanded. This is the default.
  • Include source classes—Containers that are based on the specified source classes and object tables will be expanded.
String
Container Sources
(Optional)
The container source class (or classes) and object table (or tables) that will be excluded or included depending on the rule process.
When Rule Process is set to Exclude source classes, no particular container source class or object table can be specified. In this case, all containers in the generated diagrams regardless of their source class or object table will be expanded. When Rule Process is set to Include source classes, the particular container source class (or classes) and object table (or tables) to be expanded must be specified.
When the Exclude source classes option is specified, the containers belonging to the specified source classes or object tables will not be expanded in the generated diagrams; however, container features and container objects that don't belong to those source classes and tables will be expanded. Conversely, when the Include source classes option is specified, the containers belonging to the specified source classes and object tables will be expanded in the generated diagrams; however, container features and container objects that don't belong to those source classes and object tables will not be expanded.
Table; Feature Class
(Optional)
The description of the rule.
String
Derived output
Output Network
The updated utility network or trace network.
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
