Export Diagram Template Definitions (Network Diagram Tools)
Summary
Exports the network diagram rule and layout definitions and the network diagram layer definition to .ndbd and .ndld files, respectively.
Usage
This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
The Input Network parameter value must be from a database connection established as the database utility network owner or database trace network owner.
The connected ArcGIS Enterprise portal account must be the portal utility network owner or portal trace network owner.
This tool must be connected to the default version, which is expected to be public and not protected.
The resulting
.ndbdand.ndldfiles are useful for sharing diagram template definitions or copying diagram template definitions from one network to another.
Parameters
| Label | Explanation | Data type |
Input Network |
The utility network or trace network referencing the diagram template definitions to export. |
Utility Network; Trace Network |
Input Diagram Template |
The name of the diagram template with definitions to be exported. |
String |
Output Rule and Layout Definitions File (Optional) |
The network diagram rule and layout definitions file ( |
File |
Output Diagram Layer Definition File (Optional) |
The network diagram layer definition file ( |
File |
Derived output
Output Network |
The updated utility network or trace network. |
Output Diagram Template |
The name of the diagram template. |
String |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
