Add Expand Container By Category Rule (Network Diagram Tools)
Summary
Adds a diagram rule to automatically expand container contents during the building of diagrams based on an existing template. This expansion depends on whether the containers are tagged with specific network categories.
Learn more about expanding containers in network diagrams
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network service. You must use either a utility network in a file or mobile geodatabase, or a database connection to a utility network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
    • The Input Network parameter value must be from a database connection established as the database utility network owner.
    • The connected ArcGIS Enterprise portal account must be the portal utility network owner.
    • This tool must be connected to the default version, which is expected to be public and not protected.
  • The Expand Container rule is used to expand diagrams by adding content features or objects that adhere to the following:
    • They are contained in a container in the diagram input.
    • They share the same container as content in the diagram input.
  • The Expand Container rule expands specific network container features or objects represented in diagrams. This tool allows you to configure the Expand Container rule to run by network categories. This means that you can configure the expansion of network containers in the generated diagrams depending on whether they are tagged with specific network categories.
Parameters
Label Explanation Data type
Input Network
The utility network containing the diagram template that will be modified.
Utility Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the rule will be enabled when generating and updating diagrams based on the specified template.
  • Checked—The added rule will become enabled during the generation and update of any diagrams based on the input template. This is the default.
  • Unchecked—The added rule will not become enabled during the generation or update of any diagrams based on the input template.
Boolean
Keep containers visible
Specifies whether the containers stay visible after they are expanded.
  • Checked—The containers will stay visible after they are expanded. This is the default.
  • Unchecked—The containers will be hidden after they are expanded.
Boolean
Container Type
Specifies the geometry type of the container element the rule will process.
  • Junctions only—The Expand Container rule will process the junction and junction object containers only.
  • Edges only—The Expand Container rule will process the edge and edge object containers only. Only the linear container will be processed
  • Both junctions and edges—The Expand Container rule will process any container features and objects regardless of their type. Both junction and edge types will be processed. This is the default
String
Rule Process
Specifies how the containers that are tagged with the specified network categories will be processed.
  • Exclude categories—Containers that are tagged with the specified network categories will not be expanded, while other containers will be expanded. This is the default.
  • Include categories—Containers that are tagged with the specified network categories will be expanded.
String
Categories
The network categories that will be excluded or included depending on the Rule Process parameter value.
If the Rule Process parameter is set to Include categories, one or more network categories must be specified. All containers that are tagged with the specified categories will be expanded in the generated diagrams.
If the Rule Process parameter is set to Exclude categories, the contents related to any containers that are tagged with the specified categories will not be expanded in the generated diagrams, while contents related to containers that are not tagged with the specified categories will be expanded.
String
(Optional)
The description of the rule.
String
Derived output
Output Network
The updated utility network.
Utility Network
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
