Add Start Iteration Rule (Network Diagram Tools)
Summary
Adds a diagram rule to specify the beginning of a rule sequence during diagram building based on an existing template.
Learn more about rules that are used to iterate on a particular sequences of diagram rules
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • The Start Iteration rule specifies the beginning of a rule sequence on which the diagram builder process will loop. This loop is typically configured when reducing diagram junctions because reduction rules change the number of junctions that connect to the remaining junctions. These connection changes may make some junctions become new candidates for reduction rules that are configured on the template.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template that will be modified.
Utility Network; Trace Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the rule will be enabled when generating and updating diagrams based on the specified template.
  • Checked—The added rule will become enabled during the generation and update of any diagrams based on the input template. This is the default.
  • Unchecked—The added rule will not become enabled during the generation or update of any diagrams based on the input template.
Boolean
(Optional)
The description of the rule.
String
Derived output
Output Network
The updated utility network or trace network.
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
