Delete Diagram Template (Network Diagram Tools)
Summary
Deletes a diagram template and all diagrams based on that template.
Caution:
This tool is a configuration and administration tool.
Usage
This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
The Input Network parameter value must be from a database connection established as the database utility network owner or database trace network owner.
The connected ArcGIS Enterprise portal account must be the portal utility network owner or portal trace network owner.
This tool must be connected to the default version, which is expected to be public and not protected.
Deleting a diagram template deletes all diagrams, and their content, based on that template from the database.
Parameters
| Label | Explanation | Data type |
Input Network |
The utility network or trace network related to the diagram template to delete. |
Utility Network; Trace Network |
Input Diagram Template |
The name of the diagram template to delete. |
String |
Derived output
Output Network |
The updated utility network or trace network. |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
