Add Force Directed Layout (Network Diagram Tools)
Summary
Adds the Force Directed Layout algorithm to the list of layouts to be automatically chained at the end of the building of diagrams based on a given template. This tool also presets the Force Directed Layout algorithm parameters for any diagram based on that template.
This layout algorithm uses a physical analogy to draw graphs by identifying a force system in which it tries to locally minimize the energy. It searches for an equilibrium state of the force system—a position for each diagram junction where the total force on each junction is zero.
Learn more about the Force Directed layout algorithm
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • To preset the layout algorithm parameters for a diagram based on the diagram template, uncheck the Active parameter (is_active = "INACTIVE" in Python).
  • Run the tool with Active checked (is_active = "ACTIVE" in Python) if you want the layout algorithm to be added to the list of layouts that will be automatically chained at the end of diagram generation based on the input diagram template.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template that will be modified.
Utility Network; Trace Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the layout algorithm will automatically run when generating diagrams based on the specified template.
  • Checked—The added layout algorithm will automatically run during the generation of any diagram based on the input template. This is the default. The parameter values specified for the layout algorithm are used to run the layout during diagram generation. They are also loaded by default when the algorithm is to be run on any diagram based on the input template.
  • Unchecked—All the parameter values currently specified for the added layout algorithm will be loaded by default when the algorithm is to be run on any diagram based on the input template.
Boolean
Preserve container layout
(Optional)
Specifies how the layout algorithm will process containers.
  • Checked—The layout algorithm will apply to the top graph of the diagram so container layouts are preserved.
  • Unchecked—The layout algorithm will apply to both content and noncontent features in the diagram. This is the default.
Boolean
Number of Iterations
(Optional)
The number of iterations to process. The default is 20.
Long
Repel Factor
(Optional)
Adds distance between diagram junctions that are close together. The larger the repel factor, the greater the distance that will be added between nearly overlapping diagram junctions. The default is 1.
Double
Degree of Freedom
(Optional)
Specifies the area used to move the diagram junctions during each algorithm iteration.
  • Low—The area used to move the diagram junctions will be limited. This is the default.
  • High—The area used to move the diagram junctions will be large.
  • Medium—The area used to move the diagram junctions will be moderate.
String
Break Point Relative Position (%)
(Optional)
The relative position of the two inflexion points that will be inserted along the diagram edges to compute the curved edges geometry when Edge Display Type is set to Curved edges (edges_display_type = "CURVED_EDGES" in Python). It is a percentage between 15 and 40; the default is 30. For example, with a Break Point Relative Position (%) parameter value of N between 15 and 40, the following is true:
  • X being the x-coordinate of the edge's from junction and Y being the y-coordinate of the edge's to junction for a horizontal tree:
    • The first inflexion point will be positioned at N% of the length of the [XY] segment
    • The second inflexion point will be positioned at (100 - N)% of the length of the [XY] segment
  • Y being the y-coordinate of the edge's from junction and X being the x-coordinate of the edge's to junction for a vertical tree:
    • The first inflexion point will be positioned at N% of the length of the [YX] segment
The concept of the from and to junctions above is relative to the tree direction; it is not related to the topology of the network feature or object edge.
This parameter is ignored when the Edge Display Type parameter is set to Regular edges (edges_display_type = "REGULAR_EDGES" in Python).
Double
Edge Display Type
(Optional)
Specifies the type of display for the diagram edges.
  • Regular edges—All diagram edges display as straight lines. This is the default.
  • Curved edges—All diagram edges are curved.
String
Derived output
Output Network
The updated utility network or trace network.
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
