Add Trace Rule (Network Diagram Tools)
Summary
Adds a diagram rule to the rule sequence specified on a diagram template to automatically run a trace on a utility network or trace network during diagram building. The resulting traced network features and network objects are used to build the diagram content.
Learn more about using the Trace rule to build diagrams
Caution:
This tool is a configuration and administration tool.
This tool impacts the consistency of any existing diagrams based on the input diagram template. All of the existing diagrams become inconsistent and open with a consistency warning icon until they are updated.
Usage
  • This tool is not supported when working with a utility network or trace network service. You must use either a utility network or trace network in a file or mobile geodatabase, or a database connection to a utility network or trace network in an enterprise geodatabase. When working with an enterprise geodatabase, the following are requirements:
  • The Trace rule is used to run a trace from network features or network objects currently represented in a diagram or from particular starting points specified either as input or using a Set Starting Point rule.
    Depending on the specified trace type, starting points may or must be preset in the diagram to perform the Trace rule as follows:
    • For the Connected, Subnetwork, Upstream, Downstream, and Circuit trace types, all the utility network or trace network elements represented in the diagram when the trace rule starts are considered the starting points for the trace, unless the diagram creation starts from particular trace locations provided as input or a Set Starting Point rule is configured on the diagram template to clearly identify specific starting points beforehand.
    • The Path trace type must have one or more starting and stopping locations to properly work. The Path trace type has specific requirements when used as a diagram Trace rule compared to the other trace types because stopping points cannot be specified through diagram rules. To create diagrams based on a diagram template configured to apply a Path trace type rule, the Create Diagram tool must run with the Create diagram from trace locations parameter checked.
      Tip:
      Configuring the Shortest Path Network Attribute Name parameter allows to calculate the shortest path between the specified starting and stopping locations and display the detected shortest path as a diagram.
  • When you configure a template based on a Trace rule, the trace will systematically rerun on the utility network or trace network at each diagram update. This means that any diagram based on that template will always reflect the current network trace result when updated.
  • Starting at Utility Network version 7, you can configure Trace rules to run upstream or downstream trace operations that determine flow using the digitized direction of the lines and the Flow direction attribute rather than the location of the subnetwork controllers.
  • Starting at Utility Network version 7 and Trace Network version 4, you can also configure Trace rules using named trace configurations.
  • Starting at ArcGIS Pro 3.6, you can configure the Trace rule to filter the output asset types or the type of features based on network attributes or category to return.
  • Starting at Utility Network version 8, if your utility network exists with Telecom domains, you can configure a Trace rule to run circuit traces on a telecom domain.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network containing the diagram template that will be modified.
Utility Network; Trace Network
Input Diagram Template
The name of the diagram template that will be modified.
String
Active
Specifies whether the rule will be enabled when generating and updating diagrams based on the specified template.
  • Checked—The added rule will become enabled during the generation and update of any diagrams based on the input template. This is the default.
  • Unchecked—The added rule will not become enabled during the generation or update of any diagrams based on the input template.
Boolean
Trace Type
Specifies the type of trace that will be run to build the diagram content.
  • Connected—A connected trace will be run from the utility network or trace network elements currently represented in the diagram when the rule starts and span outward along connected elements. This is the default.
  • Subnetwork—A subnetwork trace will be run from the utility network elements currently represented in the diagram when the rule starts and span outward along connected elements to find sources or sinks from which it spans outward along the related subnetwork.
  • Upstream—An upstream trace will be run from the utility network or trace network elements currently represented in the diagram when the rule starts to discover elements upstream.
  • Downstream—A downstream trace will be run from the utility network or trace network elements currently represented in the diagram when the rule starts to discover elements downstream.
  • Shortest path—A shortest path trace will be run from the utility network or trace network features currently specified as starting points in the diagram when the rule starts to discover features along the shortest path between those starting points. The cost of traversing the path is determined based on the network attribute set for the Shortest Path Network Attribute Name parameter value regardless of flow direction.
    Legacy:
    The Shortest path trace type is deprecated with ArcGIS Pro 3.7 and ArcGIS Enterprise 12.1. While it will continue to function and be an option until the next major release, we recommend that you use the Path trace type to return a shortest path. The Path trace type provides the same functionality to return a shortest path result while offering additional capabilities to find paths in your network.
  • Circuit—A circuit trace will be run from the utility network or trace network elements currently represented in the diagram when the rule starts. It will return circuit definition and path information for both physical and virtual circuits. This option is supported for telecom domain networks only.
  • Path—A path trace will be run to identify valid paths between the starting and stopping points used as input trace locations for the diagram generation.
String
Domain Network
(Optional)
The name of the domain network where the trace will be run for a utility network. This parameter is required when running the subnetwork, upstream, downstream, and circuit trace types.
String
Tier
(Optional)
The name of the tier where the trace will start for a utility network. This parameter is optional when running the connected trace type; it is required when running the subnetwork, upstream, and downstream trace types.
String
Target Tier
(Optional)
The name of the target tier to which the input tier will flow for a utility network. If this parameter is missing for upstream and downstream traces, those traces will stop when they reach the boundary of the starting subnetwork. This parameter can be used to allow these traces to continue either farther up or farther down the hierarchy.
String
Include Structures
(Optional)
Specifies whether structure features and objects will be included in the trace results.
  • Checked—Structure features and objects will be included in the trace results.
  • Unchecked—Structure features and objects will not be included in the trace results. This is the default.
Boolean
Include Barriers Features
(Optional)
Specifies whether the traversability barrier features will be included in the trace results. Traversability barriers are optional even if they have been preset in the subnetwork definition. This parameter does not apply to device features with terminals.
  • Checked—Traversability barrier features will be included in the trace results. This is the default.
  • Unchecked—Traversability barrier features will not be included in the trace results.
Boolean
Condition Barriers
(Optional)
Sets a traversability barrier condition on features based on a comparison to a network attribute or check for a category string. A condition barrier uses a network attribute or network category, an operator and a type, and an attribute value. For example, stop a trace when a feature has the Device Status attribute equal to the specific value of Open. When a feature meets this condition, the trace stops.
Value table columns:
  • Name—Filter by any network attribute defined in the system.
  • Operator—Choose from a number of different operators.
    • Is equal to—The attribute is equal to the value.
    • Does not equal—The attribute is not equal to the value.
    • Is greater than—The attribute is greater than the value.
    • Is greater than or equal to—The attribute is greater than or equal to the value.
    • Is less than—The attribute is less than the value.
    • Is less than or equal to—The attribute is less than or equal to the value.
    • Includes the values (bitwise AND equals the value)—A bitwise AND operation in which all bits in the value are present in the attribute (bitwise AND == value).
    • Does not include the values (bitwise AND does not equal the value)—A bitwise AND operation in which not all of the bits in the value are present in the attribute (bitwise AND != value).
    • Includes any (bitwise AND equals True)—A bitwise AND operation in which at least one bit in the value is present in the attribute (bitwise AND == True).
    • Does not include any (bitwise AND equals False)—A bitwise AND operation in which none of the bits in the value are present in the attribute (bitwise AND == False).
  • Type—Choose a specific value or network attribute from the value that is specified with the name.
    • Specific value—Filter by a specific value.
    • Network attribute—Filter by a network attribute.
  • Value—Provide a specific value for the input attribute type that would cause termination based on the operator value.
  • Combine Using—Set this value if you have multiple attributes to add. You can combine them using an And or an Or condition.
    • And—Combine the condition barriers.
    • Or—Use if either condition barrier is met.
Value Table
Function Barriers
(Optional)
Sets a traversability barrier on features based on a function. Function barriers can be used to do such things as restrict how far the trace travels from the starting point, or set a maximum value to stop a trace. For example, the length of each line traveled is added to the total distance traveled so far. When the total length traveled reaches the value specified, the trace stops.
  • Function—Choose from a number of different calculation functions.
    • Minimum—The minimum of the input values will be used.
    • Maximum—The maximum of the input values will be used.
    • Average—The average of the input values will be used.
    • Count—The number of features will be used.
    • Add—The sum of the values will be used.
    • Subtract—The difference between the values will be used. Subnetwork controllers and loops trace types do not support the subtract function.
  • Attribute—Filter by any network attribute defined in the system.
  • Value—Provide a specific value for the input attribute type that, if discovered, will cause the termination.
  • Use Local Values—Calculate values in each direction as opposed to an overall global value. For example, a function barrier that is calculating the sum of Shape length in which the trace terminates if the value is greater than or equal to 4. In the global case, after you traverse two edges with a value of 2, you will have reached a shape length sum of 4, so the trace stops. If local values are used, the local values along each path change, and the trace continues.
Value Table
Apply Traversability To
(Optional)
Specifies the type of traversability that will be enforced. Traversability scope defines whether traversability will be enforced at junctions, edges, or both. For example, if a condition barrier is defined to stop the trace if Device Status is equal to Open and traversability scope is set to edges only, the trace will not stop—even if it encounters an open device—because Device Status is only applicable to junctions. In other words, this parameter indicates to the trace whether to ignore junctions, edges, or both.
  • Both junctions and edges—Traversability will be applied to both junctions and edges.
  • Junctions only—Traversability will be applied to junctions only.
  • Edges only—Traversability will be applied to edges only.
  • Both junctions and edges—Traversability will be applied to both junctions and edges. This is the default.
String
Filter Barriers
(Optional)
Specifies when the trace will stop for a specific category or network attribute. For example, stop a trace at features that have a life cycle status attribute that is equal to a certain value. This parameter is used to set a terminator based on a value of a network attribute that is defined in the system.
  • Name—Filter by category or any network attribute defined in the system.
  • Value—Provide a specific value of the input attribute type that would cause termination based on the operator value.
Value Table
Filter Function Barriers
(Optional)
Filters the results of the trace for a specific category.
  • Function—Filter by a function.
  • Attribute—Filter by a network attribute.
  • Operator—Filter by an operator.
  • Value—Filter by a specific value.
  • Use Local Values—Boolean value to use local variables instead of a global variable.
Value Table
Apply Filter To
(Optional)
Specifies whether the filter for a specific category will be applied to junctions, edges, or both. For example, if a filter barrier is defined to stop the trace if Device Status is equal to Open and traversability scope is set to edges only, the trace will not stop—even if the trace encounters an open device—because Device Status is only applicable to junctions. In other words, this parameter indicates to the trace whether to ignore junctions, edges, or both.
  • Both junctions and edges—The filter will be applied to both junctions and edges. This is the default.
  • Junctions only—The filter will be applied to junctions only.
  • Edges only—The filter will be applied to edges only.
String
Filter by bitset network attribute
(Optional)
The name of the network attribute that will be used to filter by bitset. This parameter is only applicable to upstream, downstream, and loops trace types. This parameter can be used to add special logic during a trace so the trace more closely reflects real-world scenarios. For example, for a loops trace, the Phases current network attribute can determine if the loop is a true electrical loop (the same phase is energized all around the loop, that is, A) and return only real electrical loops for the trace results. An example for an upstream trace is when tracing an electric distribution network, specify a Phases current network attribute, and the trace results will only include valid paths that are specified in the network attribute, not all paths.
String
Filter by nearest
(Optional)
Specifies whether the k-nearest neighbors algorithm will be used to return a number of features of a certain type within a given distance. You can provide a count and a cost as well as a collection of categories, an asset type, or both.
  • Checked—The k-nearest neighbors algorithm will be used to return a number of features as specified in the Count, Cost Network Attribute, Nearest Categories, or Nearest Asset Groups/Types.
  • Unchecked—The k-nearest neighbors algorithm will not be used to filter results. This is the default.
Boolean
Count
(Optional)
The number of features that will be returned when Filter by nearest is checked.
Long
(Optional)
The numeric network attribute that will be used to calculate nearness, cost, or distance when Filter by nearest is checked—for example, shape length.
String
Nearest Categories
(Optional)
The categories that will be returned when Filter by nearest is checked—for example, protective.
String
(Optional)
The asset groups and asset types that will be returned when Filter by nearest is checked—for example, ElectricDistributionDevice/Transformer/Step Down.
String
Propagators
(Optional)
This parameter is only available through Python.
  • Substitution Attribute—Use a substituted value instead of bitset network attribute values. Substitutions are encoded based on the number of bits in the network attribute being propagated. A substitution is a mapping of each bit in phase to another bit. For example, for Phase AC, one substitution could map bit A to B, and bit C to null. In this example, the substitution for 1010 (Phase AC) is 0000-0010-0000-0000 (512). The substitution captures the mapping so you know that Phase A was mapped to B and Phase C was mapped to null, and not the other way around (that is, Phase A was not mapped to null and Phase C was not mapped to B).
  • Function—Choose from a number of calculation functions.
    • Propagated bitwise AND—Compare the values from one feature to the next.
    • Propagated minimum—The minimum value will be used.
    • Propagated maximum—The maximum value will be used.
  • Operator—Choose from a number of operators.
    • Does not equal—The attribute is equal to the value.
Value Table
(Optional)
The description of the rule.
String
Allow Indeterminate Flow
(Optional)
Specifies whether trace network features that have indeterminate or uninitialized flow will be traced. This parameter is only honored when running an upstream or downstream trace type.
  • Checked—Trace network features that have indeterminate or uninitialized flow direction in the trace will be included.
  • Unchecked—Trace network features that have indeterminate or uninitialized flow direction will not be included. This is the default.
Boolean
Path Direction
(Optional)
Specifies the direction of the shortest path for a trace network. The cost of traversing the path is determined by the Shortest Path Network Attribute Name parameter value. This parameter is only honored when applying a Shortest path trace type to a trace network.
  • No direction—The shortest path will be between the two starting points regardless of the direction of flow. This is the default.
  • Upstream path—The direction of the shortest path will be upstream between the two starting points.
  • Downstream path—The direction of the shortest path will be downstream between the two starting points.
String
(Optional)
The network attribute that will be used to calculate the shortest path using the path or shortest path trace type for a utility network or trace network. When running a shortest path trace type, the shortest path is calculated using a numeric network attribute such as shape length. Cost- and distance-based paths can both be achieved. This parameter is required when running a shortest path trace.
String
Use Trace Configuration
(Optional)
Specifies whether an existing named trace configuration will be used to define the properties of the trace. This parameter is only enabled for Utility Network version 7 and later.
  • Checked—An existing named trace configuration will be used to define the properties of the trace.
  • Unchecked—An existing named trace configuration will not be used to define the properties of the trace. This is the default.
Boolean
Trace Configuration Name
(Optional)
The name of the existing named trace configuration that will be used to define the properties of the trace. This parameter is only active when the Use Trace Configuration parameter is checked.
String
Use Digitized Direction
(Optional)
Specifies whether upstream and downstream trace operations will determine flow using the digitized direction of the line and the flow direction attribute. This parameter is only enabled for Utility Network version 7 and later when the Trace Type parameter is set to the Upstream or Downstream option.
This parameter requires ArcGIS Enterprise 11.3 or later when using an enterprise geodatabase.
  • Checked—The trace operations will determine flow direction using the digitized direction of the line and the flow direction attribute. With this option, the Domain Network, Tier, and Target Tier parameters are disabled.
  • Unchecked—Trace operations will determine flow direction based on the location of subnetwork controllers. This is the default.
Boolean
Output Asset Types
(Optional)
Filters the output asset types to be included in the results—for example, only return overhead transformers.
String
Output Conditions
(Optional)
The types of features that will be returned based on a network attribute or category. For example, in a trace configured to filter out everything but Tap features, any traced features that do not have the Tap category assigned to them are not included in the results. Any traced features that do are returned in the result selection set.
  • Name—Filter by network attribute name.
  • Type—Filter by a specific type.
  • Combine Using—Use this parameter to combine multiple conditions.
    • And—Combine the conditions.
    • Or—Use if either condition is met.
Value Table
Num Paths
(Optional)
The maximum number of paths that will be returned in the path or circuit trace. The default is 1. This parameter is only active when the Trace Type parameter is set to Path or Circuit.
Long
Max Hops
(Optional)
The maximum number of hops between edges allowed in the path or circuit, excluding the starting point. All edges and junction-junction connectivity associations are evaluated as having a fixed unit length of 1 on traversal. Terminal devices are evaluated as having a fixed unit length of 2. The default is 100. This parameter is only active when the Trace Type parameter is set to Path or Circuit.
Long
Infer Connectivity
(Optional)
Specifies whether the path trace will use connectivity inference to traverse containment associations and identify a path between the specified starting and stopping location. This parameter is only supported with the path trace in telecom domain networks and enables paths to be discovered between sections when connectivity information is not explicitly available. For more information, see Infer Connectivity.
  • Checked—The path trace will use connectivity inference to traverse containment associations and identify a path between the specified starting and stopping location when incomplete connectivity prevents traversal.
  • Unchecked—Connectivity inference will not be used to identify a path between the specified starting and stopping location. This is the default.
Boolean
Derived output
Output Network
The updated utility network or trace network.
Output Diagram Template
The name of the diagram template.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
