Create Diagram (Network Diagram Tools)
Summary
Creates a temporary network diagram from network features or network objects, from trace locations currently specified in the active map, or from a circuit name.
Caution:
Edits must be saved so that the output diagram is in sync with the last save of the network topology in the database. Otherwise, the unsaved edits will not be reflected in the new diagram.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Learn more about creating network diagrams
Usage
  • By default, the Create diagram from trace locations and Create diagram from circuit name parameters are unchecked and the tool searches for network features or network objects currently selected in the active map to use for the diagram creation. When run in a Python script and input layers are specified, the selection set in the map set will be ignored and the specified input layers are the only layers that will be used as input for the diagram creation.
  • To generate a diagram from trace locations, check the Create diagram from trace locations parameter. The tool will search for the starting points and barriers currently set in the network map to create the diagram. Any layers specified as feature input or network selection set existing in the map will be ignored. The trace locations currently specified in the map will be the only input used for the diagram creation.
  • To generate a diagram from a circuit name, check the Create diagram from circuit name parameter and type the name of the telecom circuit to use for the diagram creation.
  • The specified network layer, the selected network features and objects, or the specified trace locations can be from a utility network or trace network in a file or mobile geodatabase, a utility network service, or a database connection to a utility network in an enterprise geodatabase.
  • This tool creates a temporary diagram in the database. To access the diagram and use it with other tools, such as the Store Diagram tool, chain it with the Make Diagram Layer tool.
  • To generate a diagram from specific network features or network objects, you can run the Select tool or the Make Feature Layer and the Select Layer By Attribute tools before running this tool.
  • When this tool is set to operate from the selection set in the active network map, it processes both the network features selected in layers and network objects selected in nonspatial tables.
    However, nonnetwork elements that have been selected will not be included in the diagram. If only nonnetwork elements have been selected in the map, no output diagram will be created.
  • This tool will fail in the following situations:
    • There are dirty areas on network features selected in the active map.
    • There are dirty areas on container network features related to network objects selected in the nonspatial tables.
    In these cases, validate the network topology to clear the dirty areas and rerun the tool.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network from which the diagram will be created.
Utility Network; Trace Network; Utility Network Layer; Trace Network Layer
Input Template Name
The name of the template that will be used to create the diagram.
String
Features
(Optional)
One or more feature layers that will be used as input for diagram generation.
When feature layers are specified and network features or network objects are selected in the active map, the selection set is ignored and all the features in the specified layers are used as input for diagram creation.
When no feature layers are specified, the process searches for the network features and network objects selected in the active map and creates the diagram from this selection set.
This parameter can only be used when the both Create diagram from trace locations and Create diagram from circuit name parameters are unchecked.
Feature Layer
(Optional)
Specifies whether the diagram creation will be processed from trace locations.
  • Checked—The diagram creation will be processed from trace locations.
  • Unchecked—The diagram creation will not be processed from trace locations. This is the default.
Boolean
(Optional)
Specifies whether the diagram creation will be processed from a circuit name.
  • Checked—The diagram creation will be processed from a circuit name.
  • Unchecked—The diagram creation will not be processed from a circuit name. This is the default.
Boolean
Circuit Name
(Optional)
The name of the telecom circuit that will be used for the diagram.
String
Derived output
Output Network
The output utility network or trace network.
Network Diagram Name
The name of the network diagram.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
