Store Diagram (Network Diagram Tools)
Summary
Stores a temporary network diagram in the database. Access rights and tags can be assigned to control security and searchability of the diagram.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Learn more about storing network diagrams
Usage
  • This tool is not supported when working with a database connection to a utility network or trace network in an enterprise geodatabase. You must use either the related published utility network or trace network service, or a utility network or trace network in a file or mobile geodatabase.
  • The input network diagram layer must be from either a utility network or a trace network in a file or mobile geodatabase. or a network diagram service.
  • By default, a new network diagram is a temporary diagram that will be discarded when the map in which it is referenced is closed. Storing a temporary diagram allows the diagram to be retained in the database to reopen at another time.
  • To avoid unnecessarily increasing the database size and making future processes—such as copying datasets or upgrading or migrating databases—take longer, only store diagrams when necessary. Examples are storing diagrams with a refined layout that you don't want to lose or storing diagrams to share.
  • The access level applies only to stored diagrams; temporary diagrams are not available in the database and cannot be accessed by others. The only exception is when the project with the temporary diagram is saved and distributed to others.
  • Tags can be separated with the number sign (#) for efficient searches using the Find Diagrams pane.
  • Attempting to store an inconsistent diagram will fail. In this case, use the Update Diagram tool to update the diagram so it becomes consistent before storing.
  • Attempting to store a diagram with unsaved edits will fail. Any edits must be saved prior to storing a diagram to ensure that the diagram reflects the last save moment of the network topology in the database.
  • Attempting to store a diagram based on a template that has the diagram storage capability disabled will fail. Diagram storage can be blocked at the diagram template level using the Alter Diagram Template tool so database space is not wasted on stored diagrams that are not relevant.
  • When working with a utility network or trace network in a file or mobile geodatabase, diagrams can be stored with Public access rights, even without being connected to an ArcGIS Enterprise portal. However, you must be connected to store diagrams with Protected or Private access rights.
Parameters
Label Explanation Data type
Input Network Diagram Layer
The temporary network diagram layer to be stored.
Diagram Layer
Network Diagram Name
The name of the output network diagram.
Diagram Layer
Network Diagram Access Rights
(Optional)
Specifies the access right level of the input diagram.
  • Public—Other users will have full access to the diagram; everyone can see, edit, update, and overwrite the diagram. However, no one except the diagram owner and the portal utility network owner—in the case of diagrams related to a utility network in an enterprise geodatabase—can use the Alter Diagram Properties tool to change the access right level. This is the default.
  • Protected—Other users will have read-only access to the diagram. They cannot edit, update, or overwrite the diagram.
  • Private—Other users will not have access to the diagram. The corresponding diagram item will be hidden from other users in the Find Diagrams pane.
String
Tags (optional)
(Optional)
Tags help with querying the stored diagram using the Find Diagrams pane.
Use the # character to separate each tag and aid in efficient diagram searches.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
